I have noticed a wired issue with WS2811.
I have tried same sketch on both WS2812 and WS2811.
the code works as expected with WS2812 with no issue, but it goes completely bizarre when used with WS2811.
for example, the color of LED will become purple instead of Yellow. and also, the effect with WS2811 does not work as it does with WS2812.
I am aware of voltage difference; one is 5 v and the other is 12 V and I am using the two different circuits with same code.
Has anyone worked with WS2811 and experience same issue.
if not what other 12 V LEAD strip I can use that is compatible with WS2811B?
here is what I used in my code.
#include <FastLED.h>
#define LED_PIN 7
#define NUM_LEDS 7 // WS2811 has group of 3 led work together therefore the actual number should be devided by 3 ( 21 leds in strip /3 = 7)
#define BRIGHTNESS 255
CRGB leds[NUM_LEDS];
FastLED.addLeds<WS2811, LED_PIN, GRB>(leds, NUM_LEDS);
// right turn
//for(int i = NUM_LEDS - 1; i >= 0; i--) {
//leds[i] = CRGB::Red;
//FastLED.show();
//delay(70);
//leds[i] = CRGB::Black;
//left turn
for(int i = 0 ; i < NUM_LEDS; i++) {
leds[i] = CRGB::Yellow;
FastLED.show();
delay(70);
I pasted the whole code.
I am setting up the color to Yellow, but purple is what I get.
WS2811 also has group of 3 LEDs work together I suppose that makes a huge difference I suppose.
I said in my previous post that you should try the basic colors (Red, Blue, Green). That way only one LED illuminates at a time. @kolaha just told you the same thing. Why did you try Yellow?
It's not that complicated. There are only 6 possible combinations for the Color Order. You could have tried them all and gotten your answer by now.
Any time you try something new, ALWAYS post the complete, updated code in the new post.
