Issues with ZS-X11H and Motor Speed Control with ESP32
Hi, I'm testing this ZS-X11H component that I bought on Amazon: link.
Problem:
It's not working as it should when changing the motor speed.
What I did:
I used the dacWrite function on the driver's pin, which is mentioned to be 0-5V. The controller works perfectly when connected via USB, but the problems arise when trying to use it without the USB connection.
Observed Situations:
  • Connecting the 5V to the VIN of my ESP32 causes strange behaviors:
    • Sometimes the controller locks up for no apparent reason.
    • Sometimes, when I set the voltage to 0 with the DAC on the speed pin, the motor still moves very slowly.
Possible Cause:
Could it be the power supply?
Additional Tests:
I tried using PWM on the pins located next to the Hall sensor pins, specifically a pin named P, and obtained the same results. After several attempts, the controller started to lose power, and now it no longer works with either the DAC or the physical potentiometer. I assume the driver is damaged.
After the driver was damaged for no apparent reason, I continued testing with other drivers without trying the PWM pin.
Observations:
Using the dacWrite and analogWrite functions on the speed pin (not PWM), the motor works fine when connected to the PC. Isn't analogWrite supposed to be for PWM? Why does it work correctly like with the DAC?
I would appreciate any help or suggestions on what might be going wrong and how to fix it.
Your topic does not seem to indicate problems with Avrdude, stk500 or bootloader and therefore has been moved to a more suitable location on the forum.
Check out the 'ledc' family of functions, they are good for PWM stuff.
Please post schematics. The adventure at Vin sounds strange.
