I have copied a working sketch across from arduino ide to visual studio code and it is throwing an error I can't seem to get around.
Using the Adafruit_MCP4728 library I stored the Channels as a const char array to be able to iterate through them in a for loop.
const char dacCh[4] {MCP4728_CHANNEL_A, MCP4728_CHANNEL_B, MCP4728_CHANNEL_C, MCP4728_CHANNEL_D};
This would be called here
void updateDAC() {
for (int i = 0; i < windowNum; i++) {
mcp.setChannelValue(dacCh[i], windows [i].dac, MCP4728_VREF_INTERNAL, MCP4728_GAIN_2X);
in which windows[i].dac was an int variable taken from a struct.
However, I now get the error message:
argument of type "char" is incompatible with parameter of type "MCP4728_channel_t"
I have tried changing it to string but this doesn't work either?
I think MCP4728_channel_t is an enum. Try changing not to string but to MCP4728_channel_t
Awesome thank you. That worked, now it is throwing up one more error though:
"resource": "/Users/dave/Documents/PlatformIO/Projects/Power Supply/Users/dave/.platformio/packages/framework-arduino-avr/cores/arduino/Arduino.h",
"owner": "cpp",
"severity": 8,
"message": "cannot convert 'volatile uint8_t* {aka volatile unsigned char*}' to 'RwReg* {aka volatile long unsigned int*}' in assignment",
"startLineNumber": 182,
"startColumn": 97,
"endLineNumber": 182,
"endColumn": 97
the line it is referring to is this one
#define portOutputRegister(P) ( (volatile uint8_t *)( pgm_read_word( port_to_output_PGM + (P))) )
Was a problem with the configuration
system
Closed
5
