Issuesm after updating ElegantOTA version 3.1.4
Good evening to all of you,
All my sketches are developed with the OTA function.
I replaced AsyncElegantOTA with ElegantOTA a few days ago, everything went well, it compiles without errors and the code works.
When I updated ElegantOTA to version 3.1.4, then there was a lot of issues... No sketches compiled without errors (they related to the web server).
After modifying and compiling I decided to reinstall the IDE and configure it.
To be sure that my code is not in question, I compiled the "Simple_Server" example from the ESPAsyncWebServer library without problem.
On the other hand, when compiling the AsyncDemo example from the ElegantOTA library, I got a flood of errors.
The conditions of my tests are as follows:
IDE version 2.3.2
ESP8266 package 3.1.2
Libraries
ESPAsyncWebServer 3.1.0
ESPAsyncTCP 1.2.4
ElegantOTA 3.1.4
AsyncDemo compilations errors are as below:
In file included from c:\Users\Serge\Documents\Arduino\libraries\ElegantOTA\src/ElegantOTA.h:57,
                 from C:\Users\Serge\AppData\Local\Temp\.arduinoIDE-unsaved2024631-3268-1b38t6z.4ifm\AsyncDemo\AsyncDemo.ino:34:
C:\Users\Serge\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WebServer\src/ESP8266WebServer.h:47:19: error: 'HTTP_ANY' conflicts with a previous declaration
   47 | enum HTTPMethod { HTTP_ANY, HTTP_GET, HTTP_HEAD, HTTP_POST, HTTP_PUT, HTTP_PATCH, HTTP_DELETE, HTTP_OPTIONS };
In file included from C:\Users\Serge\AppData\Local\Temp\.arduinoIDE-unsaved2024631-3268-1b38t6z.4ifm\AsyncDemo\AsyncDemo.ino:33:
c:\Users\Serge\Documents\Arduino\libraries\ESPAsyncWebServer\src/ESPAsyncWebServer.h:69:3: note: previous declaration 'WebRequestMethod HTTP_ANY'
   69 |   HTTP_ANY     = 0b01111111,
C:\Users\Serge\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WebServer\src/ESP8266WebServer.h:47:29: error: 'HTTP_GET' conflicts with a previous declaration
c:\Users\Serge\Documents\Arduino\libraries\ESPAsyncWebServer\src/ESPAsyncWebServer.h:62:3: note: previous declaration 'WebRequestMethod HTTP_GET'
   62 |   HTTP_GET     = 0b00000001,
C:\Users\Serge\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WebServer\src/ESP8266WebServer.h:47:39: error: 'HTTP_HEAD' conflicts with a previous declaration
c:\Users\Serge\Documents\Arduino\libraries\ESPAsyncWebServer\src/ESPAsyncWebServer.h:67:3: note: previous declaration 'WebRequestMethod HTTP_HEAD'
   67 |   HTTP_HEAD    = 0b00100000,
C:\Users\Serge\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WebServer\src/ESP8266WebServer.h:47:50: error: 'HTTP_POST' conflicts with a previous declaration
c:\Users\Serge\Documents\Arduino\libraries\ESPAsyncWebServer\src/ESPAsyncWebServer.h:63:3: note: previous declaration 'WebRequestMethod HTTP_POST'
   63 |   HTTP_POST    = 0b00000010,
C:\Users\Serge\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WebServer\src/ESP8266WebServer.h:47:61: error: 'HTTP_PUT' conflicts with a previous declaration
c:\Users\Serge\Documents\Arduino\libraries\ESPAsyncWebServer\src/ESPAsyncWebServer.h:65:3: note: previous declaration 'WebRequestMethod HTTP_PUT'
   65 |   HTTP_PUT     = 0b00001000,
C:\Users\Serge\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WebServer\src/ESP8266WebServer.h:47:71: error: 'HTTP_PATCH' conflicts with a previous declaration
c:\Users\Serge\Documents\Arduino\libraries\ESPAsyncWebServer\src/ESPAsyncWebServer.h:66:3: note: previous declaration 'WebRequestMethod HTTP_PATCH'
   66 |   HTTP_PATCH   = 0b00010000,
C:\Users\Serge\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WebServer\src/ESP8266WebServer.h:47:83: error: 'HTTP_DELETE' conflicts with a previous declaration
c:\Users\Serge\Documents\Arduino\libraries\ESPAsyncWebServer\src/ESPAsyncWebServer.h:64:3: note: previous declaration 'WebRequestMethod HTTP_DELETE'
   64 |   HTTP_DELETE  = 0b00000100,
C:\Users\Serge\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WebServer\src/ESP8266WebServer.h:47:96: error: 'HTTP_OPTIONS' conflicts with a previous declaration
c:\Users\Serge\Documents\Arduino\libraries\ESPAsyncWebServer\src/ESPAsyncWebServer.h:68:3: note: previous declaration 'WebRequestMethod HTTP_OPTIONS'
   68 |   HTTP_OPTIONS = 0b01000000,
C:\Users\Serge\AppData\Local\Temp\.arduinoIDE-unsaved2024631-3268-1b38t6z.4ifm\AsyncDemo\AsyncDemo.ino: In function 'void setup()':
C:\Users\Serge\AppData\Local\Temp\.arduinoIDE-unsaved2024631-3268-1b38t6z.4ifm\AsyncDemo\AsyncDemo.ino:88:20: error: cannot convert 'AsyncWebServer*' to 'ESP8266WebServer*' {aka 'esp8266webserver::ESP8266WebServerTemplate<WiFiServer>*'}
   88 |   ElegantOTA.begin(&server);    // Start ElegantOTA
      |                    AsyncWebServer*
In file included from C:\Users\Serge\AppData\Local\Temp\.arduinoIDE-unsaved2024631-3268-1b38t6z.4ifm\AsyncDemo\AsyncDemo.ino:34:
c:\Users\Serge\Documents\Arduino\libraries\ElegantOTA\src/ElegantOTA.h:107:38: note:   initializing argument 1 of 'void ElegantOTAClass::begin(ESP8266WebServer*, const char*, const char*)'
  107 |     void begin(ELEGANTOTA_WEBSERVER *server, const char * username = "", const char * password = "");
exit status 1
Compilation error: cannot convert 'AsyncWebServer*' to 'ESP8266WebServer*' {aka 'esp8266webserver::ESP8266WebServerTemplate<WiFiServer>*'}
If anyone in the community is willing to look into my problem, his help would be greatly appreciated!
Thanks in advance ...
If you compile for ESP's it might be that this most verbose compile-log exceeds 120000 characters if so attach the compile-log as a textfile
Good morning StefanL38,
Thank you for your reply. The error log in my post is as it was at compile time. Anyway to satistify your request, here is attached a text file containing the error log at compile time.
Error log.txt (8,6 Ko)
Hello again StefanL38,
I wasn't really convinced that the size of the error log could be the cause of my problem, perhaps I missunderstood your explanation.
But, based on the error messages encountered, I examined the "ElegentaOTA.h" file,
and I discovered that I had to modify it to use the Asyncblabla libraries instead of ESP8266blabla.
After this modification, the compalitions took place without error.
I found on the website of the developer of ElegantOTA that he indicated this modification to be made.
It's a bit unusual, but after all, why not..
So we can close this trhead because I solved the
issue.
Thanks again for looking into my problem.
4 posts were split to a new topic: Issues after updating ElegantOTA and other libraries
