Buonasera a tutti, sono riuscito a far funzionare il driver (ST-4045-A1), tramite le uscite PWM di arduino.
int motorPin1 = 8;
int motorPin2 = 9;
int motorPin3 = 10;
int motorPin4 = 11;
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(motorPin3, OUTPUT);
pinMode(motorPin4, OUTPUT);
digitalWrite(motorPin1, LOW);
delay (3);
digitalWrite(motorPin2, HIGH);
delay (3);
digitalWrite(motorPin3, LOW);
delay (3);
digitalWrite(motorPin4, HIGH);
delay (3);
digitalWrite(motorPin1, HIGH);
delay (3);
digitalWrite(motorPin2, LOW);
delay (3);
digitalWrite(motorPin3, HIGH);
delay (3);
digitalWrite(motorPin4, LOW);
Volendo spingermi oltre, mi piacerebbe poter variare velocità e la coppia mantenendo sempre attivo il motore.
Nell' esempio riportato di seguito la velocità è variabile e il motore non è sempre attivo.
// include stepper library
#include <Stepper.h>
const int stepsPerRevolution = 200; // Nema17 motor has 200 steps in 360 degrees rotation
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8, 9, 10, 11); // pins 8,9 go to PULL+ & PULL- , pins 10,11 go to DIR+ & DIR-
int tracknumber = 2; // SET HOW MANY TRACKS YOU WANT UP AND BACK
int trackdistance = 20000;
int actualtracknumber = 0; // current track number
int motiondirection = 2; // set initial forward motor increments.
int forwardsincrement = 2; // forward
int backwardsincrement = -2; // backwards
int moves = 0; // current move number
int goforit = 1; // start or stop the move ?
int topspeed = 3201; // TOP SPEED OF TRACKING
int bottomspeed = 1; // start and end speed of RAMP up/down
int benspeed = 1; // current speed
// do some setup here
if (goforit == 1)
moveit();
donothing();
void moveit()
int x = 1;
for (int i = 50; i > -1; i = i + x ) {
if (i >= topspeed)
topspeedhold(); // hold top speed for trackdistance variable
x = -1; // switch direction at peak
if (i <= bottomspeed)
x = +1; // switch direction at troff
moves++;
actualtracknumber++;
int benspeed=i;
myStepper.setSpeed(benspeed);
myStepper.step(motiondirection);
if (moves >=1) motiondirection = backwardsincrement; // switch direction
if (moves >=2) motiondirection = forwardsincrement , moves = 0;
if (actualtracknumber >= tracknumber * 2 ) // when the motor has done forward and back the TRACKNUMBER amount set then back to void();
goforit = 0;
return;
void topspeedhold() // hold top speed for trackdistance variable
int f = 1;
for (int f = 50; f > -1; f = f + 1 ) {
if (f >= trackdistance)
return;
myStepper.setSpeed(topspeed);
void donothing()
while(1);
Se qualcuno può indicarmi un link in italiano o spiegarmi il funzionamento di ogni singola istruzione.
Grazie
