It comiles then freezes
I try to upload a sketch, something from the internet, something from the examples, it doesn't matter. When I try to upload it says it's uploading but it never stops. I tried the troubleshooting tip:
Why does the Arduino software freeze when I try to upload a program? (on Windows)?
This might be caused by a conflict with the Logitech process 'LVPrcSrv.exe'. Open the Task Manager and see if this program is running, and if so, kill it before attempting the upload. more information.
So, I looked;there is no LVPrcSrv.exe
Wait, wait... after 2or 3 minutes I have gotten this message and yes I followed the last lines instructions and they just loop to more FAQs. Any help you could provide would be appreciated!
Arduino: 1.8.12 (Windows 10), Board: "Arduino Uno"
Sketch uses 2276 bytes (7%) of program storage space. Maximum is 32256 bytes.
Global variables use 45 bytes (2%) of dynamic memory, leaving 2003 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xeb
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Remove any connections to pins 0 and 1 on your Arduino board. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Tools > Board menu.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don’t know which port is your Arduino board, you can find it like this:
  • Unplug your Arduino board from the computer.
  • Tools > Port
  • Note the ports, if any, listed in the menu.
  • Close the Tools menu. The ports list is only updated when the Tools menu is re-opened, so this step is essential.
  • Plug your Arduino board into the computer.
  • Tools > Port - The new port listed in the menu is your Arduino board.
That last part of your advice did the trick. Thank-you
You're welcome. I'm glad if I was able to be of assistance. Enjoy!
Per
