It compiles, but won't upload
I am using the bare minimum project, and this is what it says:
An error occurred while uploading the sketch
Error opening serial port 'COM3'. (Port busy)
The 'COM3' is the port for the Arduino Uno which is what I am using.
I've tried to reload Arduino multiple times but it won't change.
What OS?
What version of Arduino IDE?
Which Uno? Please link the listing you purchased it from and/or a detailed picture. A lot are clones with a CH340 instead of the 16u2, this requires another driver.
If you remove the USB cable and the selection COM3 still appears as a valid choice in the Arduino IDE then it is likely that COM3 belongs to something else.
You need to provide useful details as @er_name_not_found listed.
Adding to previous replies:
  1. That means that something else is using the port. It can be another application or a pending upload.
  2. Does the problem still show after a reboot of the PC.
  3. What does Windows device manager say?
I have sometimes more than 1 instance (not extra windows of the same instance) of the IDE running. Having the serial monitor open in one instance, will cause the error in another instance.
OS: Windows 10
Arduino IDE: 1.8.16
I'm using en Elegoo UNO, it worked perfectly in the past. It just stopped working today.
When I open the Serial monitor it crashes.
Have you restarted your PC recently?
Are you using the same USB cable?
Can you try a different cable?
