It is a good way to "jump" betwen different modes?
I want to connect my RGB strip to the arduino and I want it to light in different modes (flashing, rainbow etc).
To do so I'll have a button to change these modes. The question is: it is a good way to do so? I've seen complex programs that used different voids than setup() and loop(), should I use this method too? I'm about to make quite complex program too (changing intensity, rainbow stuff, RGB VU meter reacting to music).
I typed this short program to check if it is the good solution.
const int modeButtonPin = 2;
int mode = 0;
  pinMode(modeButtonPin, INPUT);
  int buttonState = 0;
  buttonState = digitalRead(modeButtonPin);
  if (buttonState == HIGH)
    mode = mode + 1;
    delay(50);
    else if (mode == 1)
      goto mode_1;
     else if (mode == 2)
      goto mode_2;
     else if (mode == 3)
      goto mode_3;
        else if (mode == 4)
      mode = 1;
mode_1:
  //Changing state color dynamically
  if (buttonState == HIGH){
    return;
mode_2:
  //React to music
    return;
mode_3:
  //RGB rainbow with dynamic changing speed
    return;
  //etc
Each mode contains a lot of code in it (if it changes anything).
No that's terrible.
goto is a ghost from the past, don't use it. It's 2019, we have functions :slight_smile:
Use state change detection to detect when a button becomes pressed.
And the most import thing if you want a responsive button, don't use delay() anywhere!
So instead of goto, which function should I use and how?
Also how to use the state change detection?
I put the delay to not add mode = mode + 1 turn so fast
Your own function :slight_smile: A function is what you called "void" :wink: But void simply means that function doesn't return anything.
For the state change, open the "State change"-example :wink:
If you us state change, you don't need delay() for it to not be fast. Also don't use delay() in your led modes as well.
if (mode == 2)
    aFunctionOfYourChoice();
As a matter of interest, where did you get the idea of using goto ?
These days you'd normally use switch/case for dispatch:
  switch (mode)
  case 0: mode_0() ; break ;
  case 1: mode_1() ; break ;
  case 2: mode_2() ; break ;
  case 3: mode_3() ; break ;
Very few pieces of advice should be considered absolute, and there can sometimes be a reason to deviate from what would otherwise be a best practice.
However, I can say this with absolute certainty: NEVER ever ever ever ever use
** **goto** **
. Ever.
The way you are using it here is not likely to cause problems, but that's because you are using it in a very trivial way and is pretty much identical to the switch() statement MarkT posted. However, this code is a disaster waiting to happen and a few edits could easy mix things up so badly that it can be hard to tell which gotos are going where.
So, I have just to make some of new void functions and them call them? For example:
UKHeliBob:
if (mode == 2)
and after the void loop add another, like void RGBrainbow() { ... } and it will work.
Yep!
Jiggy-Ninja:
** **goto** **
. Ever.
Except those who find it useful.
GolamMostafa:
Except those who find it useful are evil.
Fixed it!
Okey thanks guys :smiley: One more thing, why shouldn't I use the goto? It makes a big mess in my program?
It will result in so-called spaghetti code that will eventually be impossible to follow
goto is like burning your bridges. It leaves no trail home.
-jim lee
Meh, goto is very useful in some cases. Linux uses it a lot to clean up resources with error handling. Think of "goto" as a poor-man's exception mechanism.
Example code:
int foo(void)
    bool ret = false;
    int a = get_a();
    if (!a) goto out;
    int b = get_b();
    if (!b) goto cleanup_a;
    int c = get_c();
    if (!c) goto cleanup_b;
    // do something with a, b, c
    ret = true;
    cleanup_c(c);
cleanup_b:
    cleanup_b(b);
cleanup_a:
    cleanup_a(a);
out:
    return ret;
I challenge anyone to write error-handling code that's simpler and more elegant without using goto (where exceptions are not available).
That’s almost the perfect example of where a switch() case - with fall through- structure would apply !
This is a Flow Chart created in 2006 for coding purpose of an Intel-hex formatted file transfer application between PC and 80x86 Trainer. Here, the programmer had to use a lot of goto statements to arrive at different labels. Did he (the programmer) do evil job? Was it not a challenging job for him to employ while-do structure considering the time constraint of the project?
I am sure that he/she did not have to do any such thing
christop:
bool foo(void){
  bool ret = false;
  byte errorCode = 0;
  do{
    int a = get_a();
    if (!a){
      errorCode = 1;
    int b = get_b();
    if (!b){
      errorCode = 2
    int c = get_c();
    if (!c){
      errorCode = 3;
  while(false);
  switch(errorCode){
    case 0:
      ret = true;
      cleanup_c();
    case 2:
      cleanup_a();
    case 3:
      cleanup_b();
  return ret;
Thanks @septillion...
I didn’t have the patience to fight @GM tonight!
