Everything works: I'm using the UNO (Solderlab Glediator sketch) to control strands of 30mm WS2801 pixels (I am to understand these pixels already contain 3 LEDs) with Jinx! software. It all works. However, I'd like to be able to have 3 pixels, in series, operate simultaneously as 1 (as opposed to having each pixel operating independently). Is there a simple modification in the sketch that would allow this? I don't write code and have exhausted trial/error, Google, and YouTube searches.
//Change this to YOUR matrix size!!
#define Num_Pixels 20
#define CMD_NEW_DATA 1
int SDI = 3;
int CKI = 2;
unsigned char display_buffer[Num_Pixels * 3];
static unsigned char *ptr;
static unsigned int pos = 0;
volatile unsigned char go = 0;
pinMode(SDI, OUTPUT);
pinMode(CKI, OUTPUT);
//UART Initialisation
UCSR0A |= (1<<U2X0);
UCSR0B |= (1<<RXEN0) | (1<<TXEN0) | (1<<RXCIE0);
UCSR0C |= (1<<UCSZ01) | (1<<UCSZ00) ;
UBRR0H = 0;
UBRR0L = 3; //Baud Rate 0.5 MBit --> 0% Error at 16MHz :-)
ptr=display_buffer;
//Enable global interrupts
sei();
if (go==1) {shift_out_data(); go=0;}
// UART-Interrupt-Prozedur (called every time one byte is compeltely received) #
ISR(USART_RX_vect)
unsigned char b;
b=UDR0;
if (b == CMD_NEW_DATA) {pos=0; ptr=display_buffer; return;}
if (pos == (Num_Pixels*3)) {} else {*ptr=b; ptr++; pos++;}
if (pos == ((Num_Pixels*3)-1)) {go=1;}
// Shift out Data #
void shift_out_data()
for (int i=0; i<Num_Pixels; i++)
byte r = display_buffer[i*3+0];
byte g = display_buffer[i*3+1];
byte b = display_buffer[i*3+2];
for (byte j=0; j<8; j++)
digitalWrite(CKI, LOW);
if (b & (byte)(1<<(7-j))) {digitalWrite(SDI, HIGH);} else {digitalWrite(SDI, LOW);}
digitalWrite(CKI, HIGH);
if (r & (1<<(7-j))) {digitalWrite(SDI, HIGH);} else {digitalWrite(SDI, LOW);}
if (g & (1<<(7-j))) {digitalWrite(SDI, HIGH);} else {digitalWrite(SDI, LOW);}
delayMicroseconds(800); //Latch Data
