Itead HC-06 Module, how to connect to Arduino
Yes, as you can see from the title, I'm a noob. :grin:
I just bought an Arduino Starter Kit (Arduino Uno) and an HC-06 Bluetooth module, but can't figure out how to connect them together
Following is the link of the module
Thanks in advance!
Have you checked their documentation?
http://wiki.iteadstudio.com/HC06_Serial_Bluetooth_Brick#Demo
Note that this is 3,3V device. Plugging it into a 5V Arduino UNO can damage it.
Should I return it to the store? :frowning:
CarloFlores:
Why?
Is it faulty?
Hopefully not, but since I can't connect it to the Arduino I'm assuming i should return it to the store and get another one. The 4 pins can't fit on the breadboard as some youtuber did, and i don't have a grove 4 pin cable. Any suggestions on how to connect it?
Anyone else using Itead HC06?
(deleted)
Cool, thought I had to buy a different one. Thanks man!
Do you have a picture for the wiring?
Thanks again!
(deleted)
Do you know why in the overview description, it says to connect to 5V+ ? Do connect the Arduino TX to Bluetooth RX i need to apply resistor to drop the voltage, right ?
