ITG-3200 gyro
I am using this gyroscope to calculate the rotation of my robot.
Everything works fine however I struggle with identifying a specific value of a variable.
This is the code I use to calculate the change in angle:
void Robot::gyroCheck(float duration){
	int values[3] = { 0, 0, 0 };
	getGyroscopeReadings(values);
	float angle = (values[0] - xOffset) * duration / 2.96;
	totalAngle += angle;
Notice that I divide by 2.96 to get the correct angle.
I found this value by trial and error. I started with 10, changed to 5 and went down in steps until I got close and decreased the step size.
In however do not understand why I have to do this or if this is the correct value.
In some tutorial I noticed a similar technique by using such a constant and that guy named it the sensitivity of the sensor.
He calculated it by dividing the range of the sensor and the voltage change per step.
I however am not able to get the same information from the datasheet. Can someone give me some more info on this please.
The datasheet says sensitivity is 14.374 LSB / (deg/sec)
So at 1 rev/second that's 360 deg/second, so reading should be 5175.
You code is incomplete so we can't tell what units duration or xOffset are in...
duration is in seconds.
xOffset is data from the gyro. The xOffset I get from the gyro is always around -48. It's the same unit as value[0] but I don't know what it is. It's the two byte I read from the gyro which is described in the datasheet as being the data.
