Hi
I'm new user of arduino and i have a LCD ITM-12864K49.
It's possible to connect my lcd to arduino ?
Please help me thanks.
Datasheet of ITM-12864K49 : http://dragonite.dyndns.org/Elektronik/Datenblaetter/ITM-12864K49.pdf
Manu
Hi
Manu
Yeah, that looks fine for arduino. Here is the actual chip datasheet ( S6B0723 ) that you will need if you cannot find a library, it may be compatible with some other common interface. http://www.datasheetcatalog.org/datasheet/SamsungElectronic/mXuqsuq.pdf
Hi thanks for your help. Have you a sample for plug this lcd to arduino ?
Looks similar to the ST7565 so I guess any ST7565 library could be modified. I am not sure if there is a S6B0723 Arduino lib which works out of the box. Instead, we could use http://code.google.com/p/u8glib/ as base software and derive a S6B0723 from the ST7565 driver. Send me a PM if you want to do this.
Oliver
Accoding to my analysis, S6B0723 and ST7565 are nearly identical. As a first stept, please try ST7565 devices by uncommenting the constructor in the U8GLIB examples: U8GLIB_DOGM128 U8GLIB_LM6063 U8GLIB_LM6059 What will happen? Are there any results visible on the display?
Oliver
