Its OBD-II based on elm, code: Getting byte from elm, want to get output as int
Its OBD-II based on elm, code: Getting byte from elm327, want to get output as int as sensor values of cars.
BuildINString="";
while(Serial.available() > 0) // data in byte ex. >04 05 0D
inData=0; // in byte
inChar=0;
inData = Serial.read();
inChar=char(inData);
BuildINString = BuildINString + inChar;
WorkingString = BuildINString.substring(6,8); // Out of "04 05 0D" & i've to use '0D' (Hex)
int A = strtol(WorkingString.c_str(),NULL,0);
could someone pls explain me about strtol() ??
what is : WorkingString.c_str() ?? is it converting hex to dec??
if not , how can convert byte to hex here.
my final aim to get decimal data in A.
You can use this ELM327 library (also installable through the Arduino IDE's Libraries Manager - search "ELMduino").
The library in action!
What specific data are you querying for?
Also, it is NOT a good idea to use "String" variables on Arduinos.
narendok:
Here's the explanation:
