it's pin 2 How to change input to pin 8
float value=0;
float rev=0;
int rpm;
int oldtime=0;
int time;
void isr()
rev++;
attachInterrupt(0,isr,RISING);
detachInterrupt(0);
time=millis()-oldtime;
rpm=(rev/time)*60000;
oldtime=millis();
rev=0;
Serial.print("n0.val=");
Serial.print(rpm);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Interrupt 0 uses pin 2 on most (all ?) Arduinos so you cannot change it to use pin 8
You could consider using Pin Change Interrupts
the atmega328p supports interrupt on pins 2 and 3 so 0 mean pin 2 and 1 means pin 3
m_k_akash:
I use arduino nano, im beginner to use it can you help pls and write how is it work ?PLS
UKHeliBob:
how using Pin Change Interrupts, can you pls write it?
How about you try writing it yourself ? You will then learn something
Did you write teh code that you posted ?
Maybe start by looking at Pin Change Interrupts and the pages, including an example, that it links to
UKHeliBob:
i got it from internet and i tried to change input to input 8 I dont know how to change it, i can't find were is the input 2 in the code
Read reply #2
The 0 in attachInterrupt() tells the program to use pin 2
UKHeliBob:
Read reply #2
THANK YOUU a LOOOT and BIIIG LIIIKE
The more serious question is why is a "newbie" using interrupts where they are inappropriate, and why using floats? :astonished:
And, to my mind, even more interesting is WHY the OP wants to move from pin2 to pin8.
If we knew that then it would probably be much easier to provide useful information.
...R
Paul__B:
Because he/she
