Its possible to code led turn on and off but if i keep pushing the button for 5 s turn off ?
What´s the task of sketch in the real world?
that's what i want
and that's what I described in posts #2 amd #6
Yes
What should happen if the LED is turned on and the button is released within 5 seconds ? Does the LED stay on for ever ?
yes bro
It's a very common thing in the Real World that a button has to be held for (at least) a certain time before an action occurs!
Please, I am not your bro
Try this
const byte buttonPin = A3;
const byte ledPin = 3;
    pinMode(buttonPin, INPUT_PULLUP);
    pinMode(ledPin, OUTPUT);
    digitalWrite(ledPin, HIGH);  //start with LED off
    static boolean ledStaysOn = false;
    static unsigned long waitStartTime;
    unsigned long currentTime = millis();
    const unsigned long waitPeriod = 5000;
    static byte currentButtonState;
    static byte previousButtonState;
    previousButtonState = currentButtonState;
    currentButtonState = digitalRead(buttonPin);
    if (currentButtonState != previousButtonState && ledStaysOn == false)   //button state has changed
        if (currentButtonState == LOW)  //button became pressed
            digitalWrite(ledPin, LOW);  //turn on the LED
            waitStartTime = currentTime;    //save time it was turned on
        else  //button was released
            if (currentTime - waitStartTime >= waitPeriod)  //waited longer than period
                ledStaysOn = true;     //set flag to true
                digitalWrite(ledPin, HIGH);  //turn off the LED
when i hold button the led doesn't turn off she stay on
As you have confirmed in post #27.
How are the button and LED wired ?
The button should be wired to take the input LOW when the button is pressed and the LED should be wired so that it come on when its Arduino pin goes LOW
no i say i wannt the led to turn off if i keep pressing the button for 5 s
The "5 seconds" press is called "long press" in the instructions for electronic gadget world... You may see it written: 长按
Here is a longpress simulation:
