IV-18 VFD
Hi!
I have ordered a IV-18 VFD tube and have some questions.
If I understand right I do not need to use current limiting resistors on the anodes and filament?
To drive the tube I will use 2*UDN2981AT and a 4511B to save some pins (MAX6921 is to expensive).
If I drive the anodes with less than 50V it should not be any problem to use UDN2981AT as a driver IC?
/Olof
These kind of questions are often answered in the datasheet of the thingie. Do you have a link?
No it is a gas discharge tube, once it is struck you need something to limit the current so normally that is done by a resistor.
and filament?
What filaments are there then?
See here for a schematic.
http://www.larsen-b.com/Article/241.html
The driver provides current limiting.
Thanks for the answer.
I have read about different IV-18 builds on various sites and they use the MAX6921 driver IC.
I missed that the driver managed the current.
When I look at Adafruit design Ice Tube VFD Clock - How it works I only see a resistor to pin 1 which is 5V.
Pins 1 and 13 are the filament.
I have found one translated datasheet for IV-18. In the datasheet it stod the following:
Filament voltage: 5V
Filament current: 85mA (typ 75-95mA)
Anode-Grid voltage: 20-30V
Grid Current: 11mA
Total segment Current: 8mA (for one digit)
Anode-Grid current (all segment and digits lit): 25-20mA
I need to drive 8 digits one at a time so the voltage need to be increased.
Maybe it was stupid to skip MAX6921 and order UDN2981AT drivers.
The UDN2981AT was cheap but now I must limit the current with resistors.
8mA total segment current, if I got it right 1mA for one segment (8 segment for 1 digit)?
/Olof
