Ivalue required as left operand of assignment error
I have some code and when I compile it I get this error: Ivalue required as left operand of assignment error. This is only a small part of the code.
void moveServoLeftTo(int angle, int duration){
  // command the servo to move to the given angle for the given number of milliseconds
   LeftServo1.write(120);
   for (; 120 > 0; 120 -= 20){  // loop for the given number of milliseconds by subtracting 20ms each iteration
     LeftServo.refresh();             // call the service routine to move the servo
     delay(20);               // wait 20 milliseconds  between each refresh
I did not come up with or type this code, I am filling in this code. Thanks for helping.
120 -= 20
You can’t subtract a constant from another constant.
Now I getting another error when I compile it. I am getting 'class Servo' has no member named 'refresh'.
LeftServo1.refresh();
Thanks for the help.
Tonyodonnell01: I am getting 'class Servo' has no member named 'refresh'.
And what's the problem? 'class Servo' has no member named 'refresh'.
Error message cannot be much clearer. ( member means method means function )
BTW: You're using variables LeftServo and LeftServo1. Is that your intention?
Sounds like your code is from a fairly old source - refresh used to be part of the servo library, no longer needed - just delete the calls to it.
Here is the whole code. As of right now when I compile it I don’t get any errors, so all I have to do is wire everything up and test it. Thank you again for all your help.
#include <Servo.h>     // includes the servo libs
Servo LeftServo1;       // name the servo
Servo RightServo2;      // name the servo
int ultraSoundSignal = 7; // Ultrasound signal pin
int val = 0;
int val2 = 0;
int ultrasoundValue = 0;
int timecount = 0; // Echo counter
int ledPin = 13; // LED connected to digital pin 13
int lightSense = 2;
int headLight = 8;
void setup(){
   pinMode(6,OUTPUT);
   pinMode(5,OUTPUT);
   LeftServo1.attach(6);	 // Attaches the Left Servo to PWM pin 6 on the Arduino
   RightServo2.attach(5); // Attaches the Right Servo to PWM pin 5 on the Arduino
   pinMode(headLight, OUTPUT);
   pinMode(lightSense, INPUT);
   Serial.begin(9600);                  // Sets the baud rate to 9600
   pinMode(ledPin, OUTPUT);            // Sets the digital pin as output
   for (; 120 > 0; 120 - 20){  // loop for the given number of milliseconds by subtracting 20ms each iteration
	 LeftServo1;// LeftServo1.refresh(); When you said remove refresh did you mean the whole thing or just .refresh()             // call the service routine to move the servo
void moveServoRightTo(int angle, int duration){
   RightServo2.write(angle);
   for( ; 110 > 0; 110 - 20){  // loop for the given number of milliseconds by subtracting 20ms each iteration
	 RightServo2;            // call the service routine to move the servo
 // Ping))) functions: Doing more than I need it to, I think, but code
 timecount = 0;
 val = 0;
 pinMode(ultraSoundSignal, OUTPUT);   // Switch signalpin to output
  digitalWrite(ultraSoundSignal, LOW);  // Send low pulse
  delayMicroseconds(2);                 // Wait for 2 microseconds
  digitalWrite(ultraSoundSignal, HIGH); // Send high pulse
  delayMicroseconds(5);                 // Wait for 5 microseconds
  digitalWrite(ultraSoundSignal, LOW);  // Holdoff
  pinMode(ultraSoundSignal, INPUT);     // Switch signalpin to input
  val = digitalRead(ultraSoundSignal);  // Append signal value to val
  while(val == LOW) {                   // Loop until pin reads a high value
  while(val == HIGH) {                  // Loop until pin reads a high value
  timecount = timecount +1;           // Count echo pulse time
ultrasoundValue = timecount;          // Append echo pulse time to ultrasoundValue
if(timecount > 0){
  digitalWrite(ledPin, HIGH);
//delay(1);
// Servo functions: The basics
  if(ultrasoundValue > 500){
	moveServoLeftTo(45,50);   // move the left servo to 45 degrees for 500 milliseconds
	moveServoRightTo(180,50);  // moveRightTo function is left as an excercise ;)
  if(ultrasoundValue < 500){
      moveServoLeftTo(180,40);
      moveServoRightTo(180,40);
     if(ultrasoundValue < 100){
      moveServoLeftTo(180,100);
      moveServoRightTo(45,100);
      //moveServoLeftTo(45,50);
      //moveServoRightTo(180,50);
// Headlight - Turns on when photoresistor is triggered
// Doesn't seem to work on the same circuit... not sure why yet.
/*  val2 = digitalRead(lightSense);  // read input value
  if (val == HIGH) {            // check if the input is HIGH
    digitalWrite(headLight, LOW);  // turn LED OFF
    digitalWrite(headLight, HIGH); // turn LED ON
While this code may compile, it is certainly not doing what you expect. In fact, this would be an infinite loop. for() loops need a variable to be practical.
You probably meant to use something like: for (int i=120; i > 0; i = i-20) {
http://arduino.cc/en/Reference/For
Thanks, I'll try it. I was having a little trouble with that and that was going to be my next question but you got to be for I did. Thanks for help.
Yes, I know I am double posting. I was hoping somebody would have replied by now. Do you know if it would be possible to replace the servos with motors?
P.S. By the way James C4S thanks for the help. I saw a tremendous improvement once I changed it. All I have to do is come of with a debounce because the servos are moving all over the place.
Tonyodonnell01:
Sounds like you got rid of the compile errors, and were going to test something. Where is the question?
Sorry didn’t realized that it didn’t post correctly. My question was would it be possible to replace the servos with motors and do it by attaching the motors to the same pins as the servos or do I need to write some code again?
Tonyodonnell01: Sorry didn't realized that it didn't post correctly. My question was would it be possible to replace the servos with motors and do it by attaching the motors to the same pins as the servos or do I need to write some code again?
Well, depending on how you have the motor wired (as always), you can just replace calls to Servo.write to either analogWrite or digitalWrite. That will make the motor move (assuming it's attached to a transistor/h-bridge/whatever), but maybe not how you want it to. How do you want the motor to replace the servo? (Making a DC motor move like a servo with it's "go to there" command is quite hard.)
