I've got a bug in this code
int numb123 = 0;
int button = 8;
int buttonState;
const int dummy = 1;
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(8, INPUT);
  pinMode(9, OUTPUT);
  while(dummy == 1) {        // While loop that lasts forever seeing as dummy is a constant integer that is set to 1.
    // Start of the function declaration.
    void firstFunct() {
      digitalWrite(9, HIGH);
      delay(250);
      digitalWrite(9, LOW);
      delay(100);
      return 0;
    // Finish of the function declaration.
    buttonState = digitalRead(button);
    if(buttonState == LOW) {    // The light counting sequence only works if the button is not pressed, the button is intended
		if(numb123 != 32000) {
			numb123 = numb123++;        // to be a reset.
			Serial.println(numb123);
			if(numb123 < 5000) {        // As long as the number is less than 5000 the first light will be on.
				digitalWrite(2, HIGH);
				digitalWrite(3, LOW);
				digitalWrite(4, LOW);
				digitalWrite(5, LOW);
				digitalWrite(6, LOW);
			}else if((numb123 > 5000) && (numb123 < 15000)) {  // As long as the number is greater than 5000 and less than 15000 the
				digitalWrite(2, LOW);                      // second light will be on.
				digitalWrite(3, HIGH);
			}else if((numb123 > 15000) && (numb123 < 20000)) { // As long as the number is greater than 15000 and less than 20000 the
				digitalWrite(2, LOW);                      // third light will be on.
				digitalWrite(4, HIGH);
			}else if((numb123 > 20000) && (numb123 < 25000)) {  // As long as the number is greater than 20000 and less than 25000
				digitalWrite(2, LOW);                       // the fourth light will be on.
				digitalWrite(5, HIGH);
			}else if(numb123 > 25000) {                          // As long as the number is greater than 25000 the fifth light
				digitalWrite(2, LOW);                        // will be on.
				digitalWrite(6, HIGH);
		}else if (numb123 >= 32000) {
			numb123 = 32000;
			firstFunct();
	} else if (buttonState == HIGH) {               // Checks to see if the button has been pushed.
      numb123 = 0;
Please help me find the bug. It's making me like :angry: and for me, a beginner Arduino programmer, looking for the bug had me like :fearful: and I just want to be like :smiley: so any help that you have would be appreciated.
You should describe what the symptoms are, but for a start you're declaring the function "firstFunct" inside the "while()" and I don't think that's allowed.
You've got a function defined inside loop().
That's not allowed.
Consider:
which says to increment numb123 and then assign it back into itself. Most people simply would write:
On your cascading if statement, what happens when numb123 equals 5000, or 15000, or 20000, or 25000?
econjack:
Consider:
Not only that, but it is undefined.
http://c-faq.com/expr/ieqiplusplus.html
Trap #8
