I've made a graphics editor for TFT_eSPI, U8g2, AdafruitGFX, Esphome
I’ve made an open-source graphics editor designed to help create visuals for TFT_eSPI, U8g2, AdafruitGFX, and ESPHome.
Pick the GUI library or platform you're using, choose your display size, and start building with visual tools — draw shapes, add text, and more. As you work, a code window below will auto-generate the source code you can copy into your project to reproduce the design.
You can import your own images and convert them into data arrays. There's also a built-in icon library to help you get started quickly.
It’s open source and community-supported: https://github.com/sbrin/lopaka
The cloud version is live at https://lopaka.app
There’s even a gallery of editable screens and UI designs created by others, so you don’t have to start from scratch.
I'd love to hear your thoughts:
– What do you think of the idea?
– What features do you wish it had?
Your feedback is the best motivation to keep building!
Hello @ilin_pt :slight_smile:
  • The idea is more than interesting.
  • Linux version, French translation, Object libraries (buttons, menu, ...).
Questions:
  • What are the differences with the GUI Builder library?
  • Is there a complete documentation?
  • Is the current version stable to use it in a project?
I prefer an application that can be installed on your PC. An ondine application is a hindrance for me... and installing a server only for one application is too heavy for my taste. GUIslice builder works perfectly for me but I am on Linux. If you use TFT-eSPI, you can install the fonts you want in GUISlice builder. Apart from the fact that you cannot install it locally, your application has advantages.
Thank you for your questions!
I'm sorry, I can't figure out which "GUI Builder" do you mean. Could you please share a link to it?
  1. There's not much documentation yet. This is to be implemented
  2. it's quite stable, many people use it already
Nice Project. Possible Improvements:
  • change values in the Sourcecode
  • real text alignment for TFTe_Spi with tft.setTextDatum(TL_DATUM); etc.
  • support for printing variables instead of fixed texts (input variable name and type, maybe just a template with sprintf ( cString, "%type", variable) , tft.drawText( cString...) )
thank you for your effort
Bernhard
A LOT. Seriously.
Here's why I prefer Lopaka:
  • many fonts included out of the box
  • you can draw your own icons or images
  • you can copy and paste objects
  • you can select multiple objects
  • generates code on the fly
  • you can quickly share your project
  • you don't need to download anything
  • overall UX is a way much better IMO
  • works well on any system (I didn't manage to save or export anything with GuiSliceBuilder on MacOS)
Thanks! That's a very useful suggestion. I've just added variable fields for layers. Is that what you mean?
Can it handle button presses too? Touchscreen buttons.
Layers are very good. Much better orientation in the generated code.
I just cant figure out, what the checkbox "Declare Variable" does...
In my example https://lopaka.app/gallery/7584/15707
i added texts as placeholders for variables e.g.
    tft.drawString("1000.00", 20, 17);
later, in my program there are float variables for the axis-values and in the final program there will be something like
char Text[10]; sprintf( Text ,"%7.2f", fXCoordinate); tft.drawString( Text , 20, 17);
It would be cool to be able to enter a variable name (fXCoordinate) and select the data type and have the addidional code added (luxury-problem, with the layers in the comment, it is very easy to find the lines in the code).
best regards
Bernhard
Aah, i just figured out, what you generate with "Declare Variables" ... That [~] Icon right of the differnet entry-boxes is hard to recognize when it is not selected! Now, as i figured it out, my code looks as follows:
    // fXCoorinate
    tft.setFreeFont(&FreeMonoBold24pt7b);
    tft.drawString(fXCoorinate_text, 20, 17);
    // fYCoordinate
    tft.drawString(fYCoordinate_text, 20, 77);
    // fZCoordinate
    tft.drawString(fZCoordinate_text, 20, 137);
NICE! :smiley:
Just one more thing... i just added a second layer to the project. Many objects are the same so i tried copy-past between layers, which did not work. So i copied the code, clicked the second layer, clicked import code, generated a temporary text-file, paste&save, import.
With the imported code, some texts were offset by a few pixels (maybe those were marked with different alignements in the source screen).
Next tiny improval would be to set the name of the wrapper-funtion to the name of the screen. :slight_smile:
And next for the wish-list: import code from clipboard :+1:
regards
Bernhard
Website is great and useful, but why the hell did you implemented this stupid login system where I always have to enter my email address in order to login to your website? Can’t you code a normal username/password system? This is really stupid idea
