Hello,
I’m having troubles figuring out why this code wont work, can someone knowledgeable please take a look and advise? When I input into directions for my car into the serial monitor I only receive back "wrong entry’. Many thanks. James
// TRANSMITTER CODE
//NOTE :- THIS CODE IS USED WHEN YOU WANT TO CONTROL THE ROBOT VIA THE COMPUTER!!!!
#include <VirtualWire.h>
Serial.begin(9600); // Debugging only
Serial.println("setup");
// Initialise the IO and ISR
vw_setup(2000); // Bits per sec
vw_set_tx_pin(3); //Transmitter Data Pin to Digital Pin 3
}//close setup
if (Serial.available() > 0)
int sendByte = Serial.read();//Starts reading data from the serial monitor once condition is met
switch (sendByte){
case 'f': //if the controller type f
char *msg2 = "f";
digitalWrite(13, true); // Flash a light to show transmitting
vw_send((uint8_t *)msg2, strlen(msg2));//send byte to the receiver
vw_wait_tx(); // Wait until the whole message is gone
digitalWrite(13, false);
case 'b': //if controller types b
char *msg2 = "b";
case 's': //if controller types s
char *msg2 = "s";
case 'l': //if controller types l
char *msg2 = "l";
case 'r': //if controller types r
char *msg2 = "r";
default://if any other value is entered
Serial.println("wrong entry");//print wrong entry in the serial monitor
}// close switch-case
}//close if
}//close loop
// End Of Code
