Jason Coon code not working because
Downloaded this demo reel as I just made my own Fibonacci display.
Fibonacci Demo Reel: GitHub - jasoncoon/fibonacci-demoreel: Fibonacci Demo Reel for any Arduino-compatible microcontroller.
Copyright (C) 2020 Jason Coon
Using the most recent FastLED I get this error: GradientPalettes.h No such file or directory.
Did FastLED stop supporting this? And as for NO such file or directory, I found a copy of GradientPalettes.h and have included within the FastLED libraries folder so I know it is there. Why does Arduino IDE tell me it doesn't exist. I'm quite puzzled over this.
Probably because you told it to look in the wrong place. Post the code, using code tags, and the complete error message.
GradientPalettes.h is in the GitHub project so you SHOULD have included it in your sketch folder. I downloaded the project as a '.zip' file and expanded it. Renamed the result from 'fibonacci-demoreel-master' to 'fibonacci-demoreel'. Opened 'fibonacci-demoreel/fibonacci-demoreel.ino' and was able to verify the code without error.
“Should have included it in my sketch folder?” I thought, because it’s tied into FastLED, that it (.h) should be included within the FastLED libraries folder. So you suggest anywhere in my sketch folder? I can do that.
Thanks and I hope it works. I’ve tried to install GradientPalettes.h via the Library Manager within the Arduino IDE but Library Manager, even though GradientPalettes.h IS in the Libraries folder, can’t see it.
Great I did as you suggested and the GradientPalettes.h missing error is no longer there! Great.
However there is another unexpected error that perhaps you've encountered:
redefination of 'TProgmemRGBGradientPalette_byte' const gGradientPalettes []'
How did you get through this hurdle?
Post the complete error message.
Okay here is the error message from Arduino IDE
Arduino: 1.8.19 (Mac OS X), TD: 1.56, Board: "Arduino Duemilanove or Diecimila, ATmega328P"
/private/var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/AppTranslocation/53FC28AB-4420-4AEF-99B6-353894A20A8C/d/Arduino 3.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /private/var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/AppTranslocation/53FC28AB-4420-4AEF-99B6-353894A20A8C/d/Arduino 3.app/Contents/Java/hardware -hardware /Users/alfredolivas/Library/Arduino15/packages -tools /private/var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/AppTranslocation/53FC28AB-4420-4AEF-99B6-353894A20A8C/d/Arduino 3.app/Contents/Java/tools-builder -tools /private/var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/AppTranslocation/53FC28AB-4420-4AEF-99B6-353894A20A8C/d/Arduino 3.app/Contents/Java/hardware/tools/avr -tools /Users/alfredolivas/Library/Arduino15/packages -built-in-libraries /private/var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/AppTranslocation/53FC28AB-4420-4AEF-99B6-353894A20A8C/d/Arduino 3.app/Contents/Java/libraries -libraries /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries -fqbn=arduino:avr:diecimila:cpu=atmega328 -ide-version=10819 -build-path /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_build_515110 -warnings=none -build-cache /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_cache_612808 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.avr-gcc.path=/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -verbose /Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/FibonacciDemoReel.ino.ino
/private/var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/AppTranslocation/53FC28AB-4420-4AEF-99B6-353894A20A8C/d/Arduino 3.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /private/var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/AppTranslocation/53FC28AB-4420-4AEF-99B6-353894A20A8C/d/Arduino 3.app/Contents/Java/hardware -hardware /Users/alfredolivas/Library/Arduino15/packages -tools /private/var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/AppTranslocation/53FC28AB-4420-4AEF-99B6-353894A20A8C/d/Arduino 3.app/Contents/Java/tools-builder -tools /private/var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/AppTranslocation/53FC28AB-4420-4AEF-99B6-353894A20A8C/d/Arduino 3.app/Contents/Java/hardware/tools/avr -tools /Users/alfredolivas/Library/Arduino15/packages -built-in-libraries /private/var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/AppTranslocation/53FC28AB-4420-4AEF-99B6-353894A20A8C/d/Arduino 3.app/Contents/Java/libraries -libraries /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries -fqbn=arduino:avr:diecimila:cpu=atmega328 -ide-version=10819 -build-path /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_build_515110 -warnings=none -build-cache /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_cache_612808 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.avr-gcc.path=/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -verbose /Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/FibonacciDemoReel.ino.ino
Using board 'diecimila' from platform in folder: /Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4
Using core 'arduino' from platform in folder: /Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4
Detecting libraries used...
/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/cores/arduino -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/variants/standard /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_build_515110/sketch/FibonacciDemoReel.ino.ino.cpp -o /dev/null
Alternatives for FastLED.h: [FastLED@3.4.0 FastLED-master@3.3.3 FastLED-3.5.0@3.5.0]
ResolveLibrary(FastLED.h)
  -> candidates: [FastLED@3.4.0 FastLED-master@3.3.3 FastLED-3.5.0@3.5.0]
/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/cores/arduino -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/variants/standard -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_build_515110/sketch/FibonacciDemoReel.ino.ino.cpp -o /dev/null
Alternatives for Button.h: [Button-master@1.0.0]
ResolveLibrary(Button.h)
  -> candidates: [Button-master@1.0.0]
/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/cores/arduino -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/variants/standard -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/Button-master /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_build_515110/sketch/FibonacciDemoReel.ino.ino.cpp -o /dev/null
Alternatives for GradientPalettes.h: [fibonacci-demoreel]
ResolveLibrary(GradientPalettes.h)
  -> candidates: [fibonacci-demoreel]
/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/cores/arduino -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/variants/standard -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/Button-master -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_build_515110/sketch/FibonacciDemoReel.ino.ino.cpp -o /dev/null
/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/cores/arduino -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/variants/standard -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/Button-master -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/FastLED.cpp -o /dev/null
/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/cores/arduino -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/variants/standard -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/Button-master -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/bitswap.cpp -o /dev/null
/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/cores/arduino -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/variants/standard -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/Button-master -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/colorpalettes.cpp -o /dev/null
/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/cores/arduino -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/variants/standard -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/Button-master -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/colorutils.cpp -o /dev/null
/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/cores/arduino -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/variants/standard -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/Button-master -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/hsv2rgb.cpp -o /dev/null
/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/cores/arduino -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/variants/standard -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/Button-master -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/lib8tion.cpp -o /dev/null
/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/cores/arduino -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/variants/standard -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/Button-master -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/noise.cpp -o /dev/null
/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/cores/arduino -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/variants/standard -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/Button-master -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/platforms/esp/32/clockless_rmt_esp32.cpp -o /dev/null
/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/cores/arduino -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/variants/standard -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/Button-master -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/platforms.cpp -o /dev/null
/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/cores/arduino -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/variants/standard -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/Button-master -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/power_mgt.cpp -o /dev/null
/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/cores/arduino -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/variants/standard -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/Button-master -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/wiring.cpp -o /dev/null
/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/cores/arduino -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/variants/standard -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/Button-master -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/Button-master/Button.cpp -o /dev/null
Generating function prototypes...
/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/cores/arduino -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/variants/standard -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/Button-master -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_build_515110/sketch/FibonacciDemoReel.ino.ino.cpp -o /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_build_515110/preproc/ctags_target_for_gcc_minus_e.cpp
"/private/var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/AppTranslocation/53FC28AB-4420-4AEF-99B6-353894A20A8C/d/Arduino 3.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_build_515110/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Users/alfredolivas/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_DUEMILANOVE -DARDUINO_ARCH_AVR -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/cores/arduino -I/Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/variants/standard -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/Button-master -I/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_build_515110/sketch/FibonacciDemoReel.ino.ino.cpp -o /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_build_515110/sketch/FibonacciDemoReel.ino.ino.cpp.o
In file included from /Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/FibonacciDemoReel.ino.ino:23:0:
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/FastLED.h:14:21: note: #pragma message: FastLED version 3.004.000
 #    pragma message "FastLED version 3.004.000"
In file included from /Users/alfredolivas/Library/Arduino15/packages/arduino/hardware/avr/1.8.4/cores/arduino/Arduino.h:28:0,
                 from /var/folders/5c/6t7s01sn4db00kncp3sf1wpr0000gn/T/arduino_build_515110/sketch/FibonacciDemoReel.ino.ino.cpp:1:
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte ib_jul01_gp []'
 #define FL_PROGMEM                PROGMEM
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/colorutils.h:1672:52: note: in expansion of macro 'FL_PROGMEM'
   extern const TProgmemRGBGradientPalette_byte X[] FL_PROGMEM =
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:13:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(ib_jul01_gp) {
In file included from /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/FastLED.h:58:0,
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:13:26: note: 'TProgmemRGBGradientPalette_byte ib_jul01_gp [16]' previously defined here
 DEFINE_GRADIENT_PALETTE( ib_jul01_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/colorutils.h:1672:48: note: in definition of macro 'DEFINE_GRADIENT_PALETTE'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte es_vintage_57_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:25:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(es_vintage_57_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:24:26: note: 'TProgmemRGBGradientPalette_byte es_vintage_57_gp [20]' previously defined here
 DEFINE_GRADIENT_PALETTE( es_vintage_57_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte es_vintage_01_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:38:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(es_vintage_01_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:36:26: note: 'TProgmemRGBGradientPalette_byte es_vintage_01_gp [32]' previously defined here
 DEFINE_GRADIENT_PALETTE( es_vintage_01_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte es_rivendell_15_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:54:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(es_rivendell_15_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:51:26: note: 'TProgmemRGBGradientPalette_byte es_rivendell_15_gp [20]' previously defined here
 DEFINE_GRADIENT_PALETTE( es_rivendell_15_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte rgi_15_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:67:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(rgi_15_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:63:26: note: 'TProgmemRGBGradientPalette_byte rgi_15_gp [36]' previously defined here
 DEFINE_GRADIENT_PALETTE( rgi_15_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte retro2_16_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:84:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(retro2_16_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:79:26: note: 'TProgmemRGBGradientPalette_byte retro2_16_gp [8]' previously defined here
 DEFINE_GRADIENT_PALETTE( retro2_16_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte Analogous_1_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:94:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(Analogous_1_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:88:26: note: 'TProgmemRGBGradientPalette_byte Analogous_1_gp [20]' previously defined here
 DEFINE_GRADIENT_PALETTE( Analogous_1_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte es_pinksplash_08_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:107:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(es_pinksplash_08_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:100:26: note: 'TProgmemRGBGradientPalette_byte es_pinksplash_08_gp [20]' previously defined here
 DEFINE_GRADIENT_PALETTE( es_pinksplash_08_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte es_pinksplash_07_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:120:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(es_pinksplash_07_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:112:26: note: 'TProgmemRGBGradientPalette_byte es_pinksplash_07_gp [28]' previously defined here
 DEFINE_GRADIENT_PALETTE( es_pinksplash_07_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte Coral_reef_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:135:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(Coral_reef_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:126:26: note: 'TProgmemRGBGradientPalette_byte Coral_reef_gp [24]' previously defined here
 DEFINE_GRADIENT_PALETTE( Coral_reef_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte es_ocean_breeze_068_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:149:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(es_ocean_breeze_068_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:139:26: note: 'TProgmemRGBGradientPalette_byte es_ocean_breeze_068_gp [24]' previously defined here
 DEFINE_GRADIENT_PALETTE( es_ocean_breeze_068_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte es_ocean_breeze_036_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:163:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(es_ocean_breeze_036_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:152:26: note: 'TProgmemRGBGradientPalette_byte es_ocean_breeze_036_gp [16]' previously defined here
 DEFINE_GRADIENT_PALETTE( es_ocean_breeze_036_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte departure_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:175:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(departure_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:163:26: note: 'TProgmemRGBGradientPalette_byte departure_gp [48]' previously defined here
 DEFINE_GRADIENT_PALETTE( departure_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte es_landscape_64_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:195:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(es_landscape_64_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:182:26: note: 'TProgmemRGBGradientPalette_byte es_landscape_64_gp [36]' previously defined here
 DEFINE_GRADIENT_PALETTE( es_landscape_64_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte es_landscape_33_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:212:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(es_landscape_33_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:198:26: note: 'TProgmemRGBGradientPalette_byte es_landscape_33_gp [24]' previously defined here
 DEFINE_GRADIENT_PALETTE( es_landscape_33_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte rainbowsherbet_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:226:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(rainbowsherbet_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:211:26: note: 'TProgmemRGBGradientPalette_byte rainbowsherbet_gp [28]' previously defined here
 DEFINE_GRADIENT_PALETTE( rainbowsherbet_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte gr65_hult_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:241:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(gr65_hult_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:225:26: note: 'TProgmemRGBGradientPalette_byte gr65_hult_gp [24]' previously defined here
 DEFINE_GRADIENT_PALETTE( gr65_hult_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte gr64_hult_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:255:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(gr64_hult_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:238:26: note: 'TProgmemRGBGradientPalette_byte gr64_hult_gp [32]' previously defined here
 DEFINE_GRADIENT_PALETTE( gr64_hult_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte GMT_drywet_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:271:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(GMT_drywet_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:253:26: note: 'TProgmemRGBGradientPalette_byte GMT_drywet_gp [28]' previously defined here
 DEFINE_GRADIENT_PALETTE( GMT_drywet_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte ib15_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:286:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(ib15_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:267:26: note: 'TProgmemRGBGradientPalette_byte ib15_gp [24]' previously defined here
 DEFINE_GRADIENT_PALETTE( ib15_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte Fuschia_7_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:300:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(Fuschia_7_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:280:26: note: 'TProgmemRGBGradientPalette_byte Fuschia_7_gp [20]' previously defined here
 DEFINE_GRADIENT_PALETTE( Fuschia_7_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte es_emerald_dragon_08_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:313:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(es_emerald_dragon_08_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:292:26: note: 'TProgmemRGBGradientPalette_byte es_emerald_dragon_08_gp [16]' previously defined here
 DEFINE_GRADIENT_PALETTE( es_emerald_dragon_08_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte lava_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:325:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(lava_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:303:26: note: 'TProgmemRGBGradientPalette_byte lava_gp [52]' previously defined here
 DEFINE_GRADIENT_PALETTE( lava_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte fire_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:346:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(fire_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:323:26: note: 'TProgmemRGBGradientPalette_byte fire_gp [28]' previously defined here
 DEFINE_GRADIENT_PALETTE( fire_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte Colorfull_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:361:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(Colorfull_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:337:26: note: 'TProgmemRGBGradientPalette_byte Colorfull_gp [44]' previously defined here
 DEFINE_GRADIENT_PALETTE( Colorfull_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte Magenta_Evening_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:380:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(Magenta_Evening_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:355:26: note: 'TProgmemRGBGradientPalette_byte Magenta_Evening_gp [28]' previously defined here
 DEFINE_GRADIENT_PALETTE( Magenta_Evening_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte Pink_Purple_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:395:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(Pink_Purple_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:369:26: note: 'TProgmemRGBGradientPalette_byte Pink_Purple_gp [44]' previously defined here
 DEFINE_GRADIENT_PALETTE( Pink_Purple_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte Sunset_Real_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:414:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(Sunset_Real_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:387:26: note: 'TProgmemRGBGradientPalette_byte Sunset_Real_gp [28]' previously defined here
 DEFINE_GRADIENT_PALETTE( Sunset_Real_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte es_autumn_19_gp []'
Multiple libraries were found for "FastLED.h"
 Used: /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:429:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(es_autumn_19_gp) {
 Not used: /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED-master
 Not used: /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED-3.5.0
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:401:26: note: 'TProgmemRGBGradientPalette_byte es_autumn_19_gp [52]' previously defined here
 DEFINE_GRADIENT_PALETTE( es_autumn_19_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte BlacK_Blue_Magenta_White_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:450:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(BlacK_Blue_Magenta_White_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:421:26: note: 'TProgmemRGBGradientPalette_byte BlacK_Blue_Magenta_White_gp [28]' previously defined here
 DEFINE_GRADIENT_PALETTE( BlacK_Blue_Magenta_White_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte BlacK_Magenta_Red_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:465:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(BlacK_Magenta_Red_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:435:26: note: 'TProgmemRGBGradientPalette_byte BlacK_Magenta_Red_gp [20]' previously defined here
 DEFINE_GRADIENT_PALETTE( BlacK_Magenta_Red_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte BlacK_Red_Magenta_Yellow_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:478:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(BlacK_Red_Magenta_Yellow_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:447:26: note: 'TProgmemRGBGradientPalette_byte BlacK_Red_Magenta_Yellow_gp [28]' previously defined here
 DEFINE_GRADIENT_PALETTE( BlacK_Red_Magenta_Yellow_gp ) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED/src/fastled_progmem.h:33:35: error: redefinition of 'TProgmemRGBGradientPalette_byte Blue_Cyan_Yellow_gp []'
/Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/GradientPalettes.ino:493:1: note: in expansion of macro 'DEFINE_GRADIENT_PALETTE'
 DEFINE_GRADIENT_PALETTE(Blue_Cyan_Yellow_gp) {
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:461:26: note: 'TProgmemRGBGradientPalette_byte Blue_Cyan_Yellow_gp [20]' previously defined here
 DEFINE_GRADIENT_PALETTE( Blue_Cyan_Yellow_gp ) {
GradientPalettes:512:55: error: redefinition of 'TProgmemRGBGradientPalette_byte* const gGradientPalettes []'
 const TProgmemRGBGradientPalettePtr gGradientPalettes[] = {
In file included from /Users/alfredolivas/Desktop/Arduino/Sketchbook/FibonacciDemoReel.ino/FibonacciDemoReel.ino.ino:28:0:
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:479:37: note: 'TProgmemRGBGradientPalette_byte* const gGradientPalettes [33]' previously defined here
GradientPalettes:549:15: error: redefinition of 'const uint8_t gGradientPaletteCount'
 const uint8_t gGradientPaletteCount =
/Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel/GradientPalettes.h:516:15: note: 'const uint8_t gGradientPaletteCount' previously defined here
Using library FastLED at version 3.4.0 in folder: /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/FastLED
Using library Button-master at version 1.0.0 in folder: /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/Button-master
Using library fibonacci-demoreel in folder: /Users/alfredolivas/Desktop/Arduino/Sketchbook/libraries/fibonacci-demoreel (legacy)
exit status 1
type or paste code here
This is a first for me: I read what I posted (error code) and found the issues. It was just a matter of the .INO name. One name had a hyphen whereas I named my sketch without a hyphen. Once I removed the hyphen all was well.
