mrburnette:
PHP on server side, like:
Ex: http://makezine.com/2013/06/19/arduino-powered-poker-table/
Note added: the author is using a PC server with Ajax & PHP. See link in article for code.
That is actually a pretty cool project. I don't think this is quite what I am looking for. It looks like a good way to do buttons, but it is not with html or Java (I am looking at index.php).
zoomkat:
Could someone guide me in the direction of a tutorial that showed how to use a button on the webserver with Java or a .html file?
Test code with basic button type actions.
//zoomkat 8-04-12
//simple button GET server code to control servo and arduino pins 5, 6, and 7
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use ' instead of " in the html
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
///note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
pinMode(5, OUTPUT); //pin selected to control
pinMode(6, OUTPUT); //pin selected to control
pinMode(7, OUTPUT); //pin selected to control
pinMode(8, OUTPUT); //pin selected to control
//start Ethernet
Ethernet.begin(mac, ip, gateway, gateway, subnet);
server.begin();
//enable serial data print
Serial.println("server multi pin button test 1.0"); // so I can keep track of what is loaded
void loop(){
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("");
client.println("");
client.println("Arduino GET test page");
client.println("");
client.println("");
client.println("
Zoomkat's simple Arduino button
// For simple testing, pin 5, 6, 7, and 8 are used in buttons
// DIY buttons
client.println("
ON");
client.println("
OFF");
client.println("
ALL OFF
// mousedown buttons
client.println("<input type=button value=ON onmousedown=location.href='/?on4;'>");
client.println("<input type=button value=OFF onmousedown=location.href='/?off5;'>");
client.println(" <input type=button value='ALL OFF' onmousedown=location.href='/?off3579;'>
// mousedown radio buttons
client.println("<input type=radio onmousedown=location.href='/?on6;'>ON</>");
client.println("<input type=radio onmousedown=location.href='/?off7;'>OFF</>");
client.println(" <input type=radio onmousedown=location.href='/?off3579;'>ALL OFF</>
// custom buttons
client.print("<input type=submit value=ON style=width:100px;height:45px onClick=location.href='/?on8;'>");
client.print("<input type=submit value=OFF style=width:100px;height:45px onClick=location.href='/?off9;'>");
client.print(" <input type=submit value='ALL OFF' style=width:100px;height:45px onClick=location.href='/?off3579;'>");
client.println("");
client.println("");
delay(1);
//stopping client
client.stop();
///////////////////// control arduino pin
if(readString.indexOf('2') >0)//checks for 2
digitalWrite(5, HIGH); // set pin 5 high
Serial.println("Led 5 On");
if(readString.indexOf('3') >0)//checks for 3
digitalWrite(5, LOW); // set pin 5 low
Serial.println("Led 5 Off");
if(readString.indexOf('4') >0)//checks for 4
digitalWrite(6, HIGH); // set pin 6 high
Serial.println("Led 6 On");
if(readString.indexOf('5') >0)//checks for 5
digitalWrite(6, LOW); // set pin 6 low
Serial.println("Led 6 Off");
if(readString.indexOf('6') >0)//checks for 6
digitalWrite(7, HIGH); // set pin 7 high
Serial.println("Led 7 On");
if(readString.indexOf('7') >0)//checks for 7
digitalWrite(7, LOW); // set pin 7 low
Serial.println("Led 7 Off");
if(readString.indexOf('8') >0)//checks for 8
digitalWrite(8, HIGH); // set pin 8 high
Serial.println("Led 8 On");
if(readString.indexOf('9') >0)//checks for 9
digitalWrite(8, LOW); // set pin 8 low
Serial.println("Led 8 Off");
//clearing string for next read
readString="";
I have seen many tutorials that were very similar to this, but I don't know how to apply this example to a file saved on my SD card. If all the html was in client.println it would be fine, but it is a saved file.
