Good day.
I’m trying to run the sample code for a bluetooth module from Sparkfun. Here’s the code, for inquisitive/testing minds.
Example Bluetooth Serial Passthrough Sketch
by: Jim Lindblom
SparkFun Electronics
date: February 26, 2013
license: Public domain
This example sketch converts an RN-42 bluetooth module to
communicate at 9600 bps (from 115200), and passes any serial
data between Serial Monitor and bluetooth module.
#include <SoftwareSerial.h>
int bluetoothTx = 2; // TX-O pin of bluetooth mate, Arduino D2
int bluetoothRx = 3; // RX-I pin of bluetooth mate, Arduino D3
SoftwareSerial bluetooth(bluetoothTx, bluetoothRx);
Serial.begin(9600); // Begin the serial monitor at 9600bps
bluetooth.begin(115200); // The Bluetooth Mate defaults to 115200bps
bluetooth.print("$"); // Print three times individually
bluetooth.print("$"); // Enter command mode
delay(100); // Short delay, wait for the Mate to send back CMD
bluetooth.println("U,9600,N"); // Temporarily Change the baudrate to 9600, no parity
// 115200 can be too fast at times for NewSoftSerial to relay the data reliably
bluetooth.begin(9600); // Start bluetooth serial at 9600
if(bluetooth.available()) // If the bluetooth sent any characters
// Send any characters the bluetooth prints to the serial monitor
Serial.print((char)bluetooth.read());
if(Serial.available()) // If stuff was typed in the serial monitor
// Send any characters the Serial monitor prints to the bluetooth
bluetooth.print((char)Serial.read());
// and loop forever and ever!
Source:
https://learn.sparkfun.com/tutorials/using-the-bluesmirf/example-code-using-command-mode
I’m having trouble when it comes to actually sending commands to the Bluetooth module via the Arduino as per instructions in the above link. To me, this does NOT look like something wrong with the sketch (though I could be wrong), so here’s what happens:
- I plug in the Arduino with the bluetooth module hooked up to it with the sketch already loaded.
- I open the serial console, setting the baud rate to 9600 and unchecking the line ending button.
- I type “$$$” into the command window and hit send.
Nothing happens in the serial monitor, but I get this on the Arduino IDE console:
java.io.IOException: Input/output error in writeArray
at gnu.io.RXTXPort.writeArray(Native Method)
at gnu.io.RXTXPort$SerialOutputStream.write(RXTXPort.java:1173)
at processing.app.Serial.write(Serial.java:517)
at processing.app.Serial.write(Serial.java:540)
at processing.app.SerialMonitor.send(SerialMonitor.java:200)
at processing.app.SerialMonitor.access$100(SerialMonitor.java:32)
at processing.app.SerialMonitor$4.actionPerformed(SerialMonitor.java:96)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.Component.processMouseEvent(Component.java:6505)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3320)
at java.awt.Component.processEvent(Component.java:6270)
at java.awt.Container.processEvent(Container.java:2229)
at java.awt.Component.dispatchEventImpl(Component.java:4861)
at java.awt.Container.dispatchEventImpl(Container.java:2287)
at java.awt.Component.dispatchEvent(Component.java:4687)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422)
at java.awt.Container.dispatchEventImpl(Container.java:2273)
at java.awt.Window.dispatchEventImpl(Window.java:2719)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:735)
at java.awt.EventQueue.access$200(EventQueue.java:103)
at java.awt.EventQueue$3.run(EventQueue.java:694)
at java.awt.EventQueue$3.run(EventQueue.java:692)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87)
at java.awt.EventQueue$4.run(EventQueue.java:708)
at java.awt.EventQueue$4.run(EventQueue.java:706)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:705)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
It doesn’t seem to like me telling it what to do (like a stubborn dog ). What does that stacktrace mean? How do I fix it?
