Console
portIdentifier: gnu.io.CommPortIdentifier@29453f44
null
java.lang.NullPointerException
at spring.mvc.smart.arduino.SerialReader.(SerialReader.java:30)
at spring.mvc.smart.arduino.Serial.connect(Serial.java:36)
at spring.mvc.smart.arduino.Main.main(Main.java:11)
Serial.java
package spring.mvc.smart.arduino;
import java.io.InputStream;
import java.io.OutputStream;
import gnu.io.CommPort;
import gnu.io.CommPortIdentifier;
import gnu.io.NoSuchPortException;
import gnu.io.SerialPort;
public class Serial {
public Serial() {
super();
void connect(String portName) throws Exception {
CommPortIdentifier portIdentifier = null;
try {
portIdentifier = CommPortIdentifier.getPortIdentifier(portName);
System.out.println("portIdentifier: "+ portIdentifier);
}catch(NoSuchPortException e) {
System.out.println(e.getMessage());
if (portIdentifier.isCurrentlyOwned()) {
System.out.println("Error: Port is currently in use");
CommPort commPort = portIdentifier.open(this.getClass().getName(), 2000);
if (commPort instanceof SerialPort) {
SerialPort serialPort = (SerialPort) commPort;
serialPort.setSerialPortParams(9600, SerialPort.DATABITS_8, SerialPort.STOPBITS_1, SerialPort.PARITY_NONE);
InputStream in = serialPort.getInputStream();
OutputStream out = serialPort.getOutputStream();
(new Thread(new SerialReader(in))).start();
(new Thread(new SerialWriter(out))).start();
System.out.println("Error: Only serial ports are handled by this example.");
Main
import org.springframework.context.ApplicationContext;
public class Main {
public static void main(String[] args) {
try {
(new Serial()).connect("COM8");
} catch (Exception e) {
e.printStackTrace();
SerialReader
import java.io.IOException;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.jdbc.core.JdbcTemplate;
import spring.mvc.smart.dao.ReservationDao;
import spring.mvc.smart.dto.Reservation;
import spring.mvc.smart.util.JDBUtil;
/시리얼 읽기/
public class SerialReader implements Runnable{
@Autowired
private ApplicationContext applicationContext;
private JdbcTemplate jdbcTemplate;
//@Autowired
public void setTemplate(JdbcTemplate jdbcTemplate) {
this.jdbcTemplate = (JdbcTemplate) applicationContext.getBean("jdbcTemplate");
JDBUtil.jdbcTemplate = this.jdbcTemplate;
//@Autowired
private ReservationDao reservationDao = (ReservationDao) applicationContext.getBean("reservationDao");
InputStream in;
public SerialReader(InputStream in) {
this.in = in;
@Override
public void run() {
byte[] buffer = new byte[1024];
int len = -1;
String str = "";
String strReader = "";
String lastValue = "";
int motion = 9;
int temperature = 0;
int humidity = 0;
try {
while ((len = this.in.read(buffer)) > -1) {
System.out.println("hihi");
str = new String(buffer, 0, len);
strReader += str;
System.out.println(strReader);
if(strReader.length() > 6) {
String[] strArr = strReader.split("@");
System.out.println("strArr[0]: "+strArr[0]);
if(strArr.length > 1) {
System.out.println("strArr.length: "+strArr.length);
lastValue = strArr[strArr.length-2];
System.out.println("lastValue: "+lastValue);
motion = Integer.parseInt(lastValue.split(",")[0]);
temperature = Integer.parseInt(lastValue.split(",")[1]);
humidity = Integer.parseInt(lastValue.split(",")[2]);
System.out.println("motion: "+motion+", temperature: "+temperature+", humidity: "+humidity);
Reservation reservation = new Reservation();
reservation.setIsSeating(motion);
reservation.setReservationNo(1);
Reservation beforeReservation = reservationDao.getReservation(1);
if(beforeReservation.getIsSeating() != motion) { //기존의 착석여부와 다르면
reservationDao.updateIsSeating(reservation);
} catch (IOException e) {
Serial Writer
/보내는 코드/
public class SerialWriter implements Runnable {
OutputStream out;
public SerialWriter(OutputStream out) {
this.out = out;
@Override
public void run() {
try {
int c = 0;
while ((c = System.in.read()) > -1) {
this.out.write(c);
