Java on Linino?
Dear Friends,
I'm using php to process a lot of data stored in a sqlite database on the sd card. I'm not comfortable with php programming, i prefer to program in Java.
I'm thinking about the possibility to run java programs in the Yun. There is a available jre to download called jamvm, but it seems that the project is discontinued since 2010...
An alternative should be to compile a java program to machine code like this article explains:http://www.linuxjournal.com/article/8757 .
Anybody has some experience on this or any alternative idea?
Thanks in advance
Well, the jamvm is discarded, because it need 8Mb to install, and I only have 4Mb available. I'm not sure wich packages can be uninstalled, I need another alternative...
[quote author=Roque Campos link=topic=204642.msg1506688#msg1506688 date=1387022687] Well, the jamvm is discarded, because it need 8Mb to install, and I only have 4Mb available. I'm not sure wich packages can be uninstalled, I need another alternative... [/quote]
Rootfs on External Storage: http://wiki.openwrt.org/doc/howto/extroot
I set up rootfs as 7366MB by 16GB class 10 Micro SD. Rest 8176MB format as VFat and share with Mac and PC.
root@Arduino:~# df Filesystem 1K-blocks Used Available Use% Mounted on rootfs 7543192 17540 7135816 0% / /dev/root 7168 7168 0 100% /rom tmpfs 30568 100 30468 0% /tmp tmpfs 512 0 512 0% /dev /dev/sda2 7543192 17540 7135816 0% /overlay overlayfs:/overlay 7543192 17540 7135816 0% / /dev/sda1 8372232 4 8372228 0% /mnt/sda1
sonnyyu,
This sounds very intriguing and I want to try it, but I have a few quetsions:
  1. If I do this and boot without the SD card, will it just boot the original image?
  2. Which option did you choose, pivot / or pivot /overlay ?
  3. Which version of OpenWrt is the current version of Linino based on (and what r number) ?
  4. Will pushing the WLAN reset for >30sec still revert to factory image?
Sorry for all the questions, but I want to avoid bricking my Yun, hopefully.
Thanks, Bjarne
Yes once you remove MicroSD card, it will boot from original image.
  1. Which option did you choose, pivot / or pivot /overlay ?
pivot root or pivot /overlay both works, pivot / use 1% space and pivot /overlay use less than 1% (0%) space.
  1. Which version of OpenWrt is the current version of Linino based on (and what r number) ?
No idea, Wait Federico show us light.
  1. Will pushing the WLAN reset for >30sec still revert to factory image?
remove MicroSD card, the run /usr/bin/reset-to-factory-anyway then reboot will bring back factory image. You could use hardware way as well.
Same here, I am waiting warranty is expired, then do hardware mod upgrade memory to 128MB.
Thank you for the response.
Do you use pivot / or pivot /overlay and do you see any advantage of one over the other?
Did you follow the instructions for OpenWrt 10.03 or OpenWrt 12.09, IOW did you install: block-extroot block-hotplug block-mount OR just block-mount
Edit: I just checked and block-mount seems to be already part of the install, so the question is, did you install the other two block-???
bjarne: Thank you for the response.
for my understanding only block-mount is needed, and it come with linino firmware. No software is needed to install.
I hope this can help: http://www.ardulink.org/arduino-yun-alternative/
You can use Java on a Raspberry PI or another SoC with a JVM and control Arduino from there with Ardulink.
