Java programming
Im interested in the arduino. but my programming backgroud is in java. Can the arduino be programmed using java?
Nope. If you really want to write Java, you could use the Firmata and Processing Arduino library: Arduino Playground - Processing, but it shouldn't be too hard to handle the C/C++ you need to program the Arduino directly.
thanks for the info. i checked the firmata page(Arduino Playground - Firmata) but theres no mention about the java language.
if you dont mind could you give some detailed instructions on how to interface it with java?
another question if im using java i would be able to program the arduino board right?.as in i upload the code i did in my java compiler and when i disconnect the computer from the board, and the arduino will keep that code in memory and work by itself without the computer right?. i dont want it to fucntion just as a data aquisition device
might seem a silly question but im a noob
If you are fluent in Java, then programming in C/C++ is not going to be that hard for you. The syntax is very similar and all you really need to learn are the calls for the specific libraries you will be using. Don't be phased by the fact that you have never programmed in C/C++.
yeh i went through the C code i guess its easier to learn that rather than implementing java to the arduino.
thanks delta:)
