Ok, i have my java rxtx program, and im having problems, i dont know what is wrong. i installed the RXTX stuff, and im getting errors.
package serial;
import gnu.io.CommPortIdentifier;
import gnu.io.SerialPort;
import java.io.InputStream;
import java.io.OutputStream;
import processing.app.Preferences;
public class Main {
static InputStream input;
static OutputStream output;
public static void main(String[] args) throws Exception{
Preferences.init();
System.out.println("Using port: " + Preferences.get("serial.port"));
CommPortIdentifier portId = CommPortIdentifier.getPortIdentifier(
SerialPort port = (SerialPort)portId.open("serial talk", 4000);
input = port.getInputStream();
output = port.getOutputStream();
port.setSerialPortParams(Preferences.getInteger("serial.debug_rate"),
SerialPort.DATABITS_8,
SerialPort.STOPBITS_1,
SerialPort.PARITY_NONE);
while(true){
while(input.available()>0) {
System.out.print((char)(input.read()));
preferences.init() comes in and error and this is the error code it gives me when i try to run the program.
Exception in thread "main" java.lang.RuntimeException: Uncompilable source code
at serial.Main.main(Main.java:13)
Java Result: 1
but, if i delete it, (the preferences.init()) this is the output i get is...
Using port: null
Stable Library
Native lib Version = RXTX-2.1-7
Java lib Version = RXTX-2.1-7
Exception in thread "main" gnu.io.NoSuchPortException
at gnu.io.CommPortIdentifier.getPortIdentifier(CommPortIdentifier.java:218)
at serial.Main.main(Main.java:15)
Java Result: 1
