Java with Arduino
Hello,
Does anybody know how to use Java connect Arduino?
hEAP Thanks in Advance :)
You can use the open-source RXTX library (http://rxtx.org). Or if you can use Processing instead of normal Java, you can use the Serial library: http://processing.org/reference/libraries/serial/index.html (which page also contains some good tips for debugging RXTX).
