JAVA & YUN
Latest version is JamVM 2.0.0, released on 30th July 2014. JamVM is compatible with the class-library from OpenJDK 6, 7 and 8 (the latest).
http://jamvm.sourceforge.net/
http://www.gnu.org/software/classpath/
I backport jamvm and classpath to current version.
First remove old one if it is installed.
opkg remove jamvm
opkg remove classpath
cd /mnt/sda1
wget -O  classpath_0.99-1_ar71xx.ipk https://www.dropbox.com/s/fgijxd8o8pmn2x1/classpath_0.99-1_ar71xx.ipk?dl=0 --no-check-certificate
wget -O  jamvm_2.0.0-1_ar71xx.ipk https://www.dropbox.com/s/r3vova5k09lmft1/jamvm_2.0.0-1_ar71xx.ipk?dl=0 --no-check-certificate
opkg install classpath_0.99-1_ar71xx.ipk
opkg install jamvm_2.0.0-1_ar71xx.ipk
Test jamvm installation.
root@Arduino:~# jamvm -version
java version "1.5.0"
JamVM version 2.0.0
Execution Engine: direct-threaded interpreter with stack-caching
Compiled with: gcc 4.6.3 20120201 (prerelease)
Boot Library Path: /usr/lib/classpath
Boot Class Path: /usr/share/jamvm/classes.zip:/usr/share/classpath/glibj.zip
Hello World example :
At Linux box:
sonnyyu@debian75386240:~/test$ java -version
java version "1.7.0_75"
OpenJDK Runtime Environment (IcedTea 2.5.4) (7u75-2.5.4-1~deb7u1)
OpenJDK Server VM (build 24.75-b04, mixed mode)
nano HelloWorld.java
class HelloWorld
   public static void main(String args[])
      System.out.println("Hello World");
compile HelloWorld.class file
 javac HelloWorld.java
copy HelloWorld.class into Yun
root@Arduino:/mnt/sda1# jamvm HelloWorld
Hello World
Create PDF file of US flag.
http://pdfjet.com/net/examples/example-01.html
compile Example_01.java file into Example_01.class at Linux box ( copy PDFjet.jar into same directory)
javac -classpath .:PDFjet.jar  Example_01.java
Test it at same box
java -classpath .:PDFjet.jar Example_01
copy Example_01.class file into Yun:
jamvm -classpath .:PDFjet.jar Example_01
Example_01.pdf is here
https://www.dropbox.com/s/ilcxfz9i90z3j54/Example_01.pdf?dl=0
SonnyYu, Does the dropbox belong to you? If no, how do you find? If yes, do you have more? I see you make example many times. :)
TIA Jesse
jessemonroy650:
SonnyYu,
If yes, do you have more? I see you make example many times. :slight_smile:
TIA
Jesse
https://www.dropbox.com/en/help/73
sonnyyu: https://www.dropbox.com/en/help/73
SonnyYu, Sorry I am not clear. I know dropbox. I hate dropbox. I do not like dropbox.
I ask about the updated packages you always make post about. Can you give details about packages? Did you make (compile) updated packages? Did you make more updated packages? How many other updated packages did you make?
TIA Jesse
Last few packages are not updated but backported, The source is in trunk.
Linux user space package host by package holder, I will updated my post put url in.
Yes.
Not realy, AR71XX hardware platform is old.
Not much.
JDBC connect with DB(MYSQL):
http://dev.mysql.com/downloads/connector/j/
At Linux Box:
nano JDBCExample.java
import java.sql.DriverManager;
import java.sql.Connection;
import java.sql.SQLException;
public class JDBCExample {
  public static void main(String[] argv) {
    System.out.println("-------- MySQL JDBC Connection Testing ------------");
    try {
        Class.forName("com.mysql.jdbc.Driver");
    } catch (ClassNotFoundException e) {
        System.out.println("Where is your MySQL JDBC Driver?");
        e.printStackTrace();
        return;
    System.out.println("MySQL JDBC Driver Registered!");
    Connection connection = null;
    try {
        connection = DriverManager
        .getConnection("jdbc:mysql://192.168.0.64:3306/classicmodels","root", "password");
    } catch (SQLException e) {
        System.out.println("Connection Failed! Check output console");
        return;
    if (connection != null) {
        System.out.println("You made it, take control your database now!");
        System.out.println("Failed to make connection!");
javac -classpath .:mysql-connector-java-5.1.34-bin.jar JDBCExample.java
java  -classpath .:mysql-connector-java-5.1.34-bin.jar  JDBCExample
copy mysql-connector-java-5.1.34-bin.jar and JDBCExample.class into Yun.
root@Arduino:/mnt/sda1# jamvm  -classpath .:mysql-connector-java-5.1.34-bin.jar
 JDBCExample
JDBC connect with MSSQL:
Download jtds-1.2.8.jar
http://sourceforge.net/projects/jtds/files/jtds/
At Linux Box:
nano DemoJdbcRowSet.java
import java.sql.ResultSet;
import java.sql.Statement;
import javax.sql.rowset.JdbcRowSet;
public class DemoJdbcRowSet {
  * @param args
 public static void main(String[] args) {
  // TODO Auto-generated method stub
  try {
   //import driver
   Class.forName("net.sourceforge.jtds.jdbc.Driver");
   //connection to database
   Connection conn=DriverManager.getConnection("jdbc:jtds:sqlserver://192.168.0.100:1433;databaseName=test;user=sa;password=password;");
   Statement state=conn.createStatement();
   String sql="SELECT * FROM areacode where id=1";
   ResultSet result=state.executeQuery(sql);
   while (result.next())
    System.out.println(result.getString("id")+"\t"+result.getString("areacode"));
   // TODO Auto-generated catch block
javac -classpath  .:jtds-1.2.8.jar  DemoJdbcRowSet.java
java -classpath  .:jtds-1.2.8.jar  DemoJdbcRowSet
copy jtds-1.2.8.jar and DemoJdbcRowSet.class into Yun.
root@Arduino:/mnt/sda1# jamvm  -classpath  .:jtds-1.2.8.jar  DemoJdbcRowSet
1       354
sonnyyu: JDBC connect with MSSQL:
At Linux Box:
  * @param args
  try {
   //import driver
1       354
This also does not work on the current version of Yun ((((((
