I just made this sketch to show that you can use JavaScript in your embedded webpage on the Arduino. I didn't use an SD card, or an external link. I've just put the pong game made by Joe Nesbella in an html page and then into to sketch.
It's just a proof of concept.
the sktech is about 10856 bytes and doesn't use much of SDRAM thanks to avr/pgmspace.h (a buffer of 110 bytes)
So now you know you can all make fancy webpages for your pin toggling web paged Arduinos.
Yes, you should have no problem with JavaScript because it is run in the browser, not off the server. The server just serves it up like it would HTML. Your only issue is with space.
Yes I can. I've already attached the sketch in the first post, so you can download it. Remember that this only is a simple webserver, that feeds you a webpage with pong. It doesn't use the arduino to handle buttons.
Don't forget to change IP
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192,168,1, 117 };
Well, I made this for the Arduino Ethernet shield or Arduino Ethernet with the Wiznet W5100 ethernet chip.
It also was made this for Arduino 0.22, maybe you already have Arduino 1.0?
