JawDuino Error SoftRcPulseOut' does not name a type
Greetings,
I am new to Arduino, and don't know up from down, I am trying to build the JawDuino for a Halloween prop, it looked like a cool addition to the front yard this year, but when I try to compile
the sketch I get the following ( 'SoftRcPulseOut' does not name a type ) I have tried Google machine, with little success, any help, or direction would be greatly appreciated, be easy, I am an analog guy in a digital world, LOL
Many Thanks
Phil
This is what I am trying to compile:
#define TEST_PIN 11 //pin 11 set to ground will kick off the servo sweep test
int audio_value = 0;
long lastMsg = 0;
long sleepWindow = 300000; //if 5 minutes go by with no signal, then put the servos to bed
SoftRcPulseOut servo;
volatile boolean servosEnabled = false;
volatile boolean ledsOn = true;
volatile unsigned long currentTime = 0;
volatile unsigned long lastLEDtime = 0;
unsigned long resetWait = 120000; //servos sleep if not changed within this time frame (120 secs)
set_minmax();
pinMode(TEST_PIN, INPUT); //pin 11 will be
digitalWrite(TEST_PIN, HIGH); //assign pull-up resistor
servo_test();
audio_updates(); //read sample from audio input and apply average to buffer
if (servosEnabled) {
action(); //servos are handled in the action loop
SoftRcPulseOut::refresh();
if ((millis() - lastMsg) > sleepWindow)
detach_servos();
void attach_servos() { // attach the pin to the servo object
servo.attach(2);
servosEnabled = true;
void detach_servos() { // detach the servo objects
servo.detach();
void servo_test() {
if (digitalRead(TEST_PIN) == HIGH) return;
attach_servos();
for (int i = 0; i < 360; i++) {
if (i < 180)
audio_value = i;
audio_value = 359 - i;
action();
for (int i = 0; i < 10; i++) {
delay(1);
detach_servos();
void audio_updates() {
audio_value = 0;
if (analogRead(A0) < 341) audio_value += 60;
if (analogRead(A1) < 341) audio_value += 60;
if (analogRead(A2) < 341) audio_value += 60;
if (audio_value > 0) {
lastMsg = millis(); //save the time stamp from when we last had some action
if (!servosEnabled) attach_servos();
void action() {
servo.write(audio_value);
void set_minmax() {
//set the first parameter in the following functions to a number between 0 and 180.
//I used 92 and 72 in my tests to give about 20 degrees of motion.
//You may swap the large and small numbers to reverse direction.
//Just play with them, upload the code, then ground pin 11 to run the sweep test.
// Be sure to only play with these numbers while the jaw linkage is disconnected,
// otherwise, you risk hitting mechanical limits and damaging your linkage or servo!
servo.setMinimumPulse(map(92, 0, 180, 512, 2400));
servo.setMaximumPulse(map(72, 0, 180, 512, 2400));
Please follow the advice given in the link below when posting code. Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Did you forget a #include at the top?
Library example on use of the library
All the examples have #include <SoftRcPulseOut.h>, perhaps you...
I am re-posting in the correct format, sorry for the mistake
Many Thanks
Phil
  08-14-2016 Mike North This is a little proof of concept
  to make a servo move in sync with audio.
long lastMsg = 0;
  set_minmax();
  servo_test();
      detach_servos();
  servo.attach(2);
  servo.detach();
void servo_test() {
  attach_servos();
    if (i < 180)
      audio_value = i;
    action();
      delay(1);
  detach_servos();
  audio_value = 0;
void action() {
void set_minmax() {
Sorry for the noob mistake
What's that '>' doing there?
Didn't the compiler complain?
OP, consider the above line of code and and its relation to the error posted.
Thank You all for the suggestions, I will have a go at it this evening
