JChristensen DS3232RTC library sleep time
I use this library > GitHub - JChristensen/DS3232RTC: Arduino Library for Maxim Integrated DS3232 and DS3231 Real-Time Clocks and works perfectly to sleep and wake up my arduino (with pull-up resistor)..
It's possible to make an alarm two in two hours?
Lib possibilities:
ALM1_EVERY_SECOND -- causes an alarm once per second.
ALM1_MATCH_SECONDS -- causes an alarm when the seconds match (i.e. once per minute).
ALM1_MATCH_MINUTES -- causes an alarm when the minutes and seconds match.
ALM1_MATCH_HOURS -- causes an alarm when the hours and minutes and seconds match.
ALM1_MATCH_DATE -- causes an alarm when the date of the month and hours and minutes and seconds match.
ALM1_MATCH_DAY -- causes an alarm when the day of the week and hours and minutes and seconds match.
What is the difference between:
alarm(ALM1_MATCH_SECONDS,5,0,0,0)
alarm(ALM1_MATCH_MINUTES,5,0,0,0)
alarm(ALM1_MATCH_HOURS,5,0,0,0)
Best Regards
What do you mean exactly? Trigger something in 2 hours?
J-M-L:
0h00 > wake up ... read sensores .. transmit and sleep...
2h00 > wake up ... read sensores .. transmit and sleep...
4h00 > wake up ... read sensores .. transmit and sleep...
6h00 > wake up ... read sensores .. transmit and sleep...
8h00 > wake up ... read sensores .. transmit and sleep... :slight_smile:
You cannot set an alarm every two hours like you want.
But you can set an alarm every hour:
RTC.setAlarm( ALM1_MATCH_MINUTES, 0, 0, 0, 0 );
then when the alarm is triggered, check if the hour is even:
if ( alarm( ALARM_1 ) )
  if ( ( hour & 1 ) == 0 ) // if hour is even
    // do something every two hours
:slight_smile:
guix:
good idea :wink:
Another way to do is to trigger the alarm and assign 00:00:00 on the clock
:slight_smile:
