I have a JDY-23 and I entered the command 'AT+BAUD0" (ostensibly to set the baud rate to 115,200) but that baud does not work, in fact I cannot communicate with it at all!
How can I perform a hard reset to factory defaults?
have a look at JDY-23-UserManual
what host microcontroller are you thinking of using?
the JDY23 uses 3.3V logic so if connecting to a 5V logic microcontroller you will require a level converter
I have it hooked up to an USB to 3.3V TTL Level Converter.
I was able to get it to respond to AT commands and work at baud 115,200 though I do not see it transmitting on bluetooth at all. I know it is Bluetooth 5, but even an older bluetooth card should still be able to hear it? My iPhone does not hear it either and I understand it is Bluetooth 5.
iPhones are a problem in themselves, and may not work with that module.
Until you can establish a connection with the module, it will not transmit or receive data. Try to connect with the module using an Android phone or a laptop with Bluetooth, as they don't have such strict standards.
what microcontroller do you have it connected too?
the device is BLE (Bluetooth 5.0) so will not work with Bluetooth classic devices
a modern smartphone should work with BLE
on Androids I use Serial Bluetooth Terminal when working with ESP32 BLE serial
goto the menu and select Devices and Bluetooth LE - can you see a device with broadcast name JDY-23?
