does anyone know where I can get the library jeelib.h. I need itb to compile cricket. tia
Likely from one of the links off this page:
https://jeelabs.org/w/download/
... I could not find it however. Do you have a source code link that requires this lib?
Here it is: https://github.com/jeelabs/jeelib/blob/master/JeeLib.h
"Crickeduino" by Connor Nishijima
Released under the GPLv3 License
http://www.gnu.org/licenses/gpl-3.0.en.html
This is a prank sketch designed to produce convincing cricket noises
at random intervals and go into deep sleep when not in use. Loudness
attenuation is done using my Volume library:
https://github.com/connornishijima/arduino-volume1
I developed this library specifically for this project, so that I
could hide a "cricket" in my pal's vent with magnets. By driving the
speaker or piezo with a PWM whose frequency is higher than your hearing
range, you can attenuate the perceived volume of the sound creating a
more convincing cricket.
Deep sleep is acheived with the amazing JeeLib "Sleepy" function.
Using an ATmega328p with nothing but the speaker and a ceramic resonator
to drive it at 16MHz with 5 volts, current usage is as follows:
Awake: 16.0 mA
Sleep: 0.2 mA
Estimated life on 2x 2500mAh 18650 batteries (6.6V): 438 days
(You will also lose a bit of current depending on what 5V regulator you
use, bringing the total days a bit lower. Stick to switching regulators
as opposed to linears like the LM7805.)
I haven't gotten my Volume library to run properly at 8MHz / 3.3V,
but if you can the efficency would increase by a factor of 5:
Awake: 3.60 mA
Sleep: 0.04 mA
Estimated life on 2500mAh 18650 battery: 2,191 days - no regulator needed
However, running on 3.3 volts results in only 66% the maximum volume,
so you might have to be creative on how to hide this project effectively.
16MHz boards only - only tested with ATmega328p / Arduino Uno.
This will work on 16MHz ATmega32u4 based boards like the Pro Micro if you
alter the Volume library init to use pin 3 instead of 5 or 6.
#include <Volume.h> // Used for programmatic volume control
#include <JeeLib.h> // Used for deep sleep
Volume vol; // Plug your speaker into the default pin for your board type:
// https://github.com/connornishijima/arduino-volume1#supported-pins
ISR(WDT_vect) { // Jeelib Sleepy uses this to wake back up
Sleepy::watchdogEvent();
const bool demoMode = true; // Use this to test your speaker and hear the sounds at 2sec intervals. Set to false for long sleep mode.
const unsigned int sleepTimes[] PROGMEM = {3, 10, 30, 60, 180}; // These are the random sleep intervals: 3min, 10min, 30min, 1hr, 3hr.
unsigned int sleepMinutes = 0;
// This is used to make the cricket do an initial extended
// sleep if you'd like. use anywhere from 0 to 65,535 minutes (45 days!)
// This is good for hiding the payload inconspicuously. ;)
byte repeat = 0; // Used at random to combine noises
// Do initial sleep if set
while (sleepMinutes > 0) {
int sleepTime = 60000;
Sleepy::loseSomeTime(sleepTime);
sleepMinutes--;
// Start timers for Volume lib:
vol.begin();
// Take random reading from empty analog pin to seed the Arduino's pseudo-RNG.
randomSeed(analogRead(A5));
chirpAndSleep(); // Run any extra code above this line
void chirpAndSleep() {
chirp(); // Go decide on a type of noise to make then come back
int chance = random(1, 10); // 1 in 10 chance of making two or three random noises this cycle
if (chance == 1) {
repeat = random(1, 2);
if (repeat > 0) { // If we're making more than one noise, don't sleep
repeat--;
else { // No noises left, time to sleep
if (demoMode == true) { // If we're in demo mode, don't sleep.
vol.delay(2000);
else { // If not, sleep tight!
int sleepTime = sleepTimes[random(0, 5)] + random(0, 6); // Get random time from sleepTimes list, and add a random 0-5 minutes.
// Nighty night
while (sleepTime > 0) { // sleep one minute at a time
Sleepy::loseSomeTime(60000);
sleepTime--;
void chirp() {
int freq = random(3700, 4000); // random frequency in this range is picked for this chirp
float volume = random(10, 100+1) / 100.00; // random volume between 10-100% is chosen for this chirp
int chirpType = random(0, 3); // randomly pick a type of noise to make
if (chirpType == 0) { // Burst chirp
int chirpCount = random(1, 3);
int count = random(1, 6);
while (chirpCount > 0) {
chirpLoud(count, freq, volume);
vol.delay(100);
chirpCount--;
if (chirpType == 1) { // Faded chirp
chirpFade(chirpCount, freq, volume);
if (chirpType == 2) { // Creepy rustle noise
int count = 3;
chirpNoise(count, volume);
vol.delay(10);
chirpCount--;
void chirpLoud(byte times, int freq, float volume) {
while (times > 0) {
int v = 0;
while (v < 255) {
vol.tone(freq, v * volume);
v += 4;
v = 255;
while (v > 0) {
v -= 4;
vol.delay(10);
times--;
vol.noTone();
void chirpFade(byte times, int freq, float volume) {
float fadeOut = 1.00;
while (times > 0) {
float mv = 0;
while (mv < 1.00) {
int v = 0;
while (v < 255) {
vol.tone(freq, v * volume * mv * fadeOut);
v += 4;
v = 255;
while (v > 0) {
v -= 4;
vol.delay(20);
mv += 0.2;
mv = 1.00;
while (mv > 0.00) {
int v = 0;
while (v < 255) {
v += 4;
v = 255;
while (v > 0) {
v -= 4;
vol.delay(20);
mv -= 0.2;
vol.noTone();
fadeOut -= 0.75;
times--;
void chirpNoise(byte times, float volume) {
while (times > 0) {
int v = 0;
while (v < 128) {
vol.tone(random(6000, 10000), v * volume);
v += 4;
v = 128;
while (v > 0) {
v -= 4;
vol.delay(10);
times--;
vol.noTone();
// Special thanks to Andrew Neal for dealing with this cricket for what's hopefully months.
Which Arduino board do you use ?
I put it in Wokwi:
The audio in Wokwi is not the same as in the real world.
In the sketch at Wokwi, I wrote how I did it:
Sketch from here: https://github.com/connornishijima/arduino-volume1/blob/master/examples/volume_crickeduino_prank/volume_crickeduino_prank.ino
Buzzer at pin 5.
Library "Volume" is in the Arduino IDE Library Manager.
It is therefor also in the Wokwi Library Manager.
Source code at: GitHub - connornishijima/arduino-volume1: Arduino tone() just got 8-bit volume control - with no extra components!
Library "JeeLib" is not in the Arduino IDE Library Manager.
JeeLib: GitHub - jeelabs/jeelib: JeeLib for Arduino IDE: Ports, RF12, and RF69 drivers from JeeLabs
Only the "Ports.cpp" and "Ports.h" are used, so I took those from the JeeLib library,
and uploaded them to this Wokwi project.
Changed the sketch to include "Ports.h"
