system
October 2, 2014, 10:54am
1
Hi there,
I have 4 servos which is connected to arduino digital pin 9-12.
I am using 5V 1A wall adaptor to power servos.
When i connect two servo i can't see any jerks but as soon as i insert the third servo, they all starts jerking.
the servos are not under any load. Any idea what is happening?
system
October 2, 2014, 10:59am
2
Yes, you're not showing us the whole picture.
system
October 2, 2014, 11:09am
3
I want to control 4 servo with 8 push button, 2 for each to control direction of servos.
Here is the code which i tried.
#include <Servo.h>
Servo myservo1;
Servo myservo2;
Servo myservo3;
Servo myservo4;
int button7=0;
int button6=0;
int button4=0;
int button5=0;
int button2=0;
int button3=0;
int pos1=180;
int pos2=180;
int pos3=0;
int pos4 = 90;
pinMode(2, INPUT);
pinMode(3, INPUT);
pinMode(4, INPUT);
pinMode(5, INPUT);
pinMode(7, INPUT);
pinMode(6, INPUT);
myservo1.attach(9);
myservo2.attach(10);
myservo3.attach(11);
myservo4.attach(12);
myservo4.write(pos4);
myservo3.write(pos3);
myservo2.write(pos2);
myservo1.write(pos1);
button2=digitalRead(2);
button3=digitalRead(3);
button4=digitalRead(4);
button5=digitalRead(5);
button7=digitalRead(7);
button6=digitalRead(6);
delay(15);
if(button7==1 && button6==0)
pos1=constrain(pos1,0,180);
pos1++;
if(button7==0 && button6==1)
pos1--;
if(button5==1 && button4==0)
pos2=constrain(pos2,0,180);
pos2++;
if(button5==0 && button4==1)
pos2--;
if(button3==1 && button2==0)
pos3=constrain(pos3,0,180);
pos3++;
if(button3==0 && button2==1)
pos3--;
for testing purpose i only attach the servos to arduino board to see if they are holding their respective position as set in the code
(pos1,pos2,pos3,pos4). when i attached only two servos they holding their position fine but as soon as i connect more than 2 servos they starts jerking.
using 5V 1A wall adaptor to power servos & grounds are common.
What model of servo are they? How much power do they need? In the absence of other detail, I'll guess that your power supply is inadequate.
system
October 2, 2014, 11:23am
5
Servo Specs:
Operating Voltage : 4.8-6.0V
PWM Input Range : Pulse Cycle 20±2ms, Positive Pulse 1~2ms
STD Direction : Counter Clockwise / Pulse Traveling 1500 to 1900µsec
Stall Torque : 6 kg-cm (82.6 oz/in) at 4.8V, 7.1 Kg-cm (97.3 oz/in) at 6V
Operating Speed : 0.18 sec/ 60° at 4.8V, 0.16 sec/ 60° at 6V at no load
Weight : 40g (1.41 oz)
Size : 41.320.3 38.748.5 10
Plug Available : FUT, JR
Special Feature : Heavy Duty Plastic Gears, Economy Servo
system
October 2, 2014, 11:44am
6
I'd go with inadequate power supply too.
