Hi, I am building a remote control tank using the nrf24l01 radio modules. However, the device itself and the library I used aren't of importance, since the error is in my own code. Pasted below is the code for my RECEIVER Arduino Uno. I receive and store a data struct from the radio module (the data is set by joysticks on my transmitting Arduino), then use it to set the direction and output for each of my two motors using an L923D H-Bridge Motor Driver. The problem is this:
In the positive direction, each motor works fine (one direction of the joystick, that is) The power output responds smoothly to my moving of the joystick. However, when I move the joystick in the negative direction, the motors start acting weird: they jerk back and forth as if the output weren't constant. I switched the wires and saw that the motors can run in both ways, so it's not a hardware problem. There must be something wrong in my code that messes up my PWM output when the input is negative. Please help!!
#include <SPI.h>
#include "RF24.h"
#define CE_PIN 7
#define CSN_PIN 8
RF24 radio(CE_PIN, CSN_PIN);
byte addresses[][6] = {"1Node", "2Node"};
/* DATA STRUCT TO BE RECEIVED FROM RADIO*/
struct dataStruct {
unsigned long _micros;
int power1; //an integer between -255 and 255 will be received for each motor
int power2;
bool sw1; //booleans for push-button states - ignore
bool sw2;
} myData;
const int enable_1 = 3; //Enable pin for L293D motor driver - motor 1
const int control_1a = 2; //The two control pins control which direction the current is allowed to flow
const int control_1b = 4;
const int enable_2 = 6;
const int control_2a = 5;
const int control_2b = 10;
pinMode(enable_1,OUTPUT);
pinMode(control_1a,OUTPUT);
pinMode(control_1b,OUTPUT);
pinMode(enable_2,OUTPUT);
pinMode(control_2a,OUTPUT);
pinMode(control_2b,OUTPUT);
radio.begin();
radio.setChannel(108);
radio.setDataRate(RF24_250KBPS);
radio.setPALevel(RF24_PA_LOW);
radio.openWritingPipe(addresses[1]);
radio.openReadingPipe(1, addresses[0]);
radio.startListening();
/**** This entire loop "if radio.available" simply stores the received information into my declared data struct: myData ****/
if ( radio.available())
while (radio.available())
radio.read( &myData, sizeof(myData) );
radio.stopListening();
radio.write( &myData, sizeof(myData) );
/****** Once we have the data, first we decide what direction to set each motor ****/
if (myData.power1 < 0){ //backwards: 1
setDirec(0,1);
else if (myData.power1 > 0){ //forwards: 1
setDirec(1,1);
if (myData.power2 < 0){ //backwards: 2
setDirec(0,2);
else if (myData.power2 > 0){ //forwards: 2
setDirec(1,2);
/***** Now that we know what direction we are going in, we can get rid of signs and focus on magnitudes ******/
myData.power1 = abs(myData.power1);
myData.power2 = abs(myData.power2);
setThrottle(1,myData.power1);
setThrottle(2,myData.power2);
delay(50);
void setDirec (bool dir, int whichMot){
if (dir){
switch(whichMot){
case 1:
digitalWrite(control_1a,HIGH);
digitalWrite(control_1b,LOW);
case 2:
digitalWrite(control_2a,HIGH);
digitalWrite(control_2b,LOW);
else if (!dir){
switch(whichMot){
case 1:
digitalWrite(control_1a,LOW);
digitalWrite(control_1b,HIGH);
case 2:
digitalWrite(control_2a,LOW);
digitalWrite(control_2b,HIGH);
void setThrottle (int whichMot, int data){
switch(whichMot){
case 1:
analogWrite(enable_1,data);
case 2:
analogWrite(enable_2,data);
