Jeu Snake, besoin de conseil
Bonjour à tous !
Je suis novice en programmation, j'ai encore beaucoup à apprendre, et je me forme avec des tutoriels sur internet etc...
J'ai trouvé un code pour un jeu snake, et j'ai comme projet de le modifier afin d'intégrer des actionneurs dans ce programe.
Voici le programme que j'ai trouvé et qui marche:
#include <FastLED.h>
#include <LinkedList.h>
#define NUM_LEDS    96
#define LED_PIN     13
int rows = 8;
int columns = 12;
CRGB leds[NUM_LEDS];
//Joystick
#define PAUSE_PIN 50
const int xPin        = A6;
const int yPin        = A7;
// Directions
#define DIR_UP    0
#define DIR_DOWN  1
#define DIR_LEFT  2
#define DIR_RIGHT 3
int resetDelay = 250;
// Game State
#define MAX_SPEED 5
#define MIN_SPEED 300
#define SPEED_LOSS 15
int gameSpeed = MIN_SPEED;
int currDirection = DIR_UP;
boolean isGamePaused = false;
boolean isTogglingPause = false;
// class that represents a point on the matrix. Indexed starting at 0
class Point {
  private:
    byte x;
    byte y;
  public:
    Point(byte x, byte y) {
      this->x = x;
      this->y = y;
    byte getX() {
      return x;
    byte getY() {
      return y;
    boolean isEqual(int x, int y) {
      return this->x == x && this->y == y;
// body of the snake, last element representing the tail, first element representing the head
LinkedList<Point*> snakePositions = LinkedList<Point*>();
// where the apple is located
Point *applePosition;
// For Style ;)
CRGB appleColor = CRGB(255, 0, 0);
CRGB snakeColor = CRGB(0, 255, 0);
CRGB pausedAppleColor = CRGB(0, 255, 255);
CRGB pausedSnakeColor = CRGB(0, 0, 255);
CRGB emptyColor = CRGB(0, 0, 0);
CRGB solidColor = CRGB(255, 0, 0);
  // setup analog stick
  pinMode(xPin, INPUT);
  pinMode(yPin, INPUT);
  pinMode(PAUSE_PIN, INPUT_PULLUP);
  // pick starting position
  snakePositions.add(getStartingPosition());
  // pick apple position
  applePosition = getApplePosition();
  // setup ws2812b leds
  FastLED.addLeds<WS2812, LED_PIN, GRB>(leds, NUM_LEDS);
  // if we're paused set the scene
  checkForPause();
  if(isGamePaused) {
    pauseGame();
  }else{
    // set current direction
    currDirection = getCurrentDirection();
    // get next position
    Point *nextPoint = getNextPosition();
    // check if we are still valid and continue the game, otherwise reset it
    if(isNextPointValid(nextPoint)){
      playGame(nextPoint);
    }else{
      resetGame();
// always start the game in the same spot
Point * getStartingPosition(){
  return new Point(0,0);
// generate the position of the apple so it is not out of bounds or within the snake
Point * getApplePosition(){
  int x = random(rows);
  int y = random(columns);
  // make sure to generate an apple that is not in the same position as the snake
  while(snakeContainsPosition(x,y)){
    x = random(rows);
  return new Point(x,y);
// check if the x y coordinates are covered by a part of the snake
boolean snakeContainsPosition(int x, int y) {
  for(int i = 0; i < snakePositions.size(); i++){
    if(snakePositions.get(i)->isEqual(x,y)) {
      return true;
  return false;
// read direction from analog stick
int getCurrentDirection(){
  int dir = currDirection;
  int xPosition = analogRead(xPin);
  int yPosition = analogRead(yPin);
  int mapX = map(xPosition, 0, 1023, -512, 512);
  int mapY = map(yPosition, 0, 1023, -512, 512);
  // The max is 512, so let's assume that if the analog stick is over 3/4ths in one direction then we are good
  // Then choose the direction based on the which value is greater
  //left
  int absX = abs(mapX);
  int absY = abs(mapY);
  int threshold = 384;
  if(absX > threshold || absY > threshold) {
    dir = absX > absY ? getXDir(mapX) : getYDir(mapY);
  //ensure you can't go the direction you just came
  switch(dir) {
    case DIR_UP:
      dir = currDirection == DIR_DOWN ? DIR_DOWN : dir;
    case DIR_DOWN:
      dir = currDirection == DIR_UP ? DIR_UP : dir;
    case DIR_LEFT:
      dir = currDirection == DIR_RIGHT ? DIR_RIGHT : dir;
    case DIR_RIGHT:
      dir = currDirection == DIR_DOWN ? DIR_LEFT : dir;
    default:
  return dir;
int getYDir(int y) {
  return y > 0 ? DIR_UP : DIR_DOWN;
int getXDir(int x) {
  return x > 0 ? DIR_RIGHT : DIR_LEFT;
Point * getHead() {
  return snakePositions.get(0);
Point * getTail() {
  return snakePositions.get(snakePositions.size() - 1);
void addToBeginning(Point *p){
  snakePositions.add(0, p);
void removeTail() {
  delete(snakePositions.pop());
// calculate the next position based on the current head position and the current direction
Point * getNextPosition() {
  Point *head = getHead();
  switch(currDirection) {
    case DIR_UP:
      return new Point(head->getX(), head->getY() + 1);
    case DIR_DOWN:
      return new Point(head->getX(), head->getY() - 1);
    case DIR_LEFT:
      return new Point(head->getX() - 1, head->getY());
    case DIR_RIGHT:
      return new Point(head->getX() + 1, head->getY());
    default:
      return new Point(-9, -9);
// make sure the next point for the head of the snake is in a valid position
boolean isNextPointValid(Point *p) {
  int x = p->getX();
  int y = p->getY();
  // check if within boundary or if we are in the snake
  if(x < 0 || x >= rows || y < 0 || y >= columns || snakeContainsPosition(x,y)) {
    return false;
  return true;
// draw the apple
void renderApple() {
  leds[getIndexForPoint(applePosition)] = isGamePaused ? pausedAppleColor : appleColor;
// draw the snake
void renderSnake(){
  Point *p;
  for(int i = 0; i < snakePositions.size(); i++) {
    p = snakePositions.get(i);
    int index = getIndexForPoint(p);
    int x = p->getX();
    int y = p->getY();
    leds[index] = isGamePaused ? pausedSnakeColor : snakeColor;
// for a point in the matrix, map it to the index in the string
int getIndexForPoint(Point *p) {
  int x = p->getX();
  int y = p->getY();
  boolean oddRow = x % 2 == 1;
  // handle serpentine pattern
  if(oddRow){
    return (x + 1) * columns - y - 1;
  return x * columns  + y;
void renderEmptyScreen(){
  for(int i = 0; i < NUM_LEDS; i++) {
    leds[i] = emptyColor;
void renderSolidScreen() {
    leds[i] = solidColor;
void playGame(Point *nextPoint){
  // clear screen
  renderEmptyScreen();
  // if we land on an apple grow the snake
  if(applePosition->isEqual(nextPoint->getX(), nextPoint->getY())){
    growSnake(nextPoint);
  }else{
    moveSnake(nextPoint);
  renderSnake();
  renderApple();
  FastLED.show();
  delay(gameSpeed);
void moveSnake(Point *p){
  addToBeginning(p);
  removeTail();
void growSnake(Point *p){
  addToBeginning(p);
  resetApple();
  increaseSpeed();
void increaseSpeed() {
  gameSpeed -= SPEED_LOSS;
void checkForPause() {
  boolean isPressedDown = digitalRead(PAUSE_PIN) == 0;
  boolean shouldPause = false;
  if(isPressedDown) {
    // we are trying to pause the game and the button is held down
    isTogglingPause = true;
  }else{
    // the pause button is released, so let's trigger a pause
    shouldPause = isTogglingPause;
  if(shouldPause) {
    isGamePaused = !isGamePaused;
// initiate a different view
void pauseGame(){
  renderSnake();
  renderApple();
  FastLED.show();
// delete the snake and create a new one
void resetSnake() {
  while(snakePositions.size() > 0){
// delete the current position and draw a new apple
void resetApple() {
  delete(applePosition);
// show an end screen and reset the game state
void resetGame(){
  resetSnake();
  resetApple();
  renderSolidScreen();
  FastLED.show();
  delay(resetDelay);
  FastLED.show();
  delay(resetDelay);
  FastLED.show();
  delay(resetDelay);
  FastLED.show();
  delay(resetDelay);
  FastLED.show();
  delay(resetDelay);
  FastLED.show();
J'essaye donc de créer un programme qui actionnera un mécanisme (lockPin) une fois que le snake aura mangé 8 pommes.
J'ai crée un code avec un effet spécial une fois les 8 pommes mangées (void endGame) en créant un couleur particulière pour cet effet (void renderEndScreen)
Voici le code :
 * Simple snake game for a matrix of ws2812b leds strung up in serpentine pattern. The idea is
 * there is an apple and a snake on the board, and the snake tries to eat the apple. Each frame of the
 * game the snake moves in a single direction. If the snake is out of bounds or lands on its own tail,
 * then the game is over. If the head of the snake lands on the apple, the snake grows in length and the
 * speed of the snake increases.
//LEDs
#define NUM_LEDS    96
#define LED_PIN     13
int rows = 8;
int columns = 12;
//Joystick & Relay
const byte lockPin = A0;
// Directions
#define DIR_UP    0
#define DIR_DOWN  1
#define DIR_LEFT  2
#define DIR_RIGHT 3
// Game State
#define MAX_SPEED 5
class Point {
  private:
    byte x;
    byte y;
  public:
      this->x = x;
      this->y = y;
    byte getX() {
      return x;
    byte getY() {
      return y;
// For Style ;)
CRGB solidColor = CRGB(0, 255, 0);
CRGB endColor = CRGB(255, 0, 0);
  // Relay
  pinMode(lockPin, OUTPUT);
  digitalWrite(lockPin, HIGH);
  checkForPause();
  if(isGamePaused) {
    pauseGame();
  }else{
    }else{
      resetGame();
    x = random(rows);
      return true;
  return false;
  //left
  switch(dir) {
    case DIR_UP:
    case DIR_DOWN:
    case DIR_LEFT:
    case DIR_RIGHT:
    default:
  return dir;
Point * getHead() {
Point * getTail() {
void removeTail() {
    case DIR_UP:
    case DIR_DOWN:
    case DIR_LEFT:
    case DIR_RIGHT:
    default:
  int x = p->getX();
  int y = p->getY();
    return false;
  return true;
// draw the apple
// draw the snake
void renderSnake(){
  Point *p;
    int x = p->getX();
    int y = p->getY();
  int x = p->getX();
  int y = p->getY();
  if(oddRow){
void renderEndScreen(){
    leds[i] = endColor;
  // clear screen
  }else{
  renderSnake();
  renderApple();
  FastLED.show();
  delay(gameSpeed);
  addToBeginning(p);
  removeTail();
  addToBeginning(p);
  resetApple();
  increaseSpeed();
  if(isPressedDown) {
  }else{
  if(shouldPause) {
void pauseGame(){
  renderSnake();
  renderApple();
  FastLED.show();
void resetSnake() {
void resetApple() {
void resetGame(){
  resetSnake();
  resetApple();
  FastLED.show();
  delay(resetDelay);
  FastLED.show();
  delay(resetDelay);
  FastLED.show();
  delay(resetDelay);
  FastLED.show();
  delay(resetDelay);
  FastLED.show();
  delay(resetDelay);
  FastLED.show();
void endGame(){
  resetSnake();
  resetApple();
  renderEndScreen();
  FastLED.show();
  delay(resetDelay);
  FastLED.show();
  delay(resetDelay);
  renderEndScreen();
  FastLED.show();
  delay(resetDelay);
  FastLED.show();
  delay(resetDelay);
  renderEndScreen();
  FastLED.show();
  delay(resetDelay);
  FastLED.show();
  digitalWrite(lockPin, LOW);
  exit(0);
Le problème étant que je cherche à créer un code (que j'appelle eatApple) qui dit que quand le snake a mangé 8 pommes, l'effet void endGame s'active. J'ai essayé plusieurs tentative en vain. Si vous avez des astuces je suis preneur ! en vous remerciant par avance !
A cet endroit tu peux incrémenter un compteur de pommes : lorsque le compteur atteint 8, tu passes un flag (une variable booléenne) à true.
Dans la loop, tu vérifie si ce flag est à true : si oui, tu appelles ta fonction endGame()
Tu n'a pas créé ta fonction, il faudrait commencer par là ?
Cette fonction doit donc lorsque 8 pommes ont été mangé appel endGame
Il reste le principal, il ne me semble pas que tu compte le nombre de pomme que le serpent à mangé ?
De mon point vu, ta fonction n'est pas necessaire.
Je regarderais lorsque la tête du serpent est déplacé, si il va sur une pomme, dans ce cas, j'incrémenterais une variable du nombre de pomme consommé.
Dans la fonction plaugame ou loop, si la variable dépasse le nombre de pomme mettant fin à la partie, j'appellerais ta fonction endgame.
Je préférais le faire dans la loop.
