Jevois and stepper motors
I am using an Arduino UNO to detect an object using the jevois camera and based on the object’s position, I am moving stepper motors to desired coordinates. How can I move the motors to the coordinates? Attached is the code I used, and it would not move my motors in any direction. I think it is because the coordinates fluctuate too much for the motors to move, but I am not sure.
#include <avr/io.h>
#include <util/delay.h>
#define LEDPIN 13
#define SERIAL Serial
#define INLEN 256
char instr[INLEN + 1];
int smDirectionPin = 2; //Direction pin
int smStepPin = 3; //Stepper pin
int dir;
int centerx = -211;
int centery = 475;
int targx;
int targy;
int movement;
delay(8000);
digitalWrite(LEDPIN, HIGH); // turn LED on
digitalWrite(LEDPIN, LOW); // turn LED off
delay(200);
SERIAL.begin(115200);
SERIAL.setTimeout(1000); //* changed
pinMode(LEDPIN, OUTPUT);
// digitalWrite(LEDPIN, HIGH);
// set JeVois to detect objects with tensorflow easy: YUYV 320 308 30.0 YUYV 320 240 30.0 JeVois TensorFlowEasy
SERIAL.println(“setpar serout Hard”);
SERIAL.println(“setmapping2 YUYV 320 254 60.0 JeVois ObjectTracker”);
SERIAL.println(“streamon”);
pinMode(smDirectionPin, OUTPUT);
pinMode(smStepPin, OUTPUT);
for(int j = 0; j < 5; j++){
if (j == 1){
byte len = SERIAL.readBytesUntil(’\n’, instr, INLEN);
instr[len–] = ‘\0’;
while (len >= 0 && instr[len] == ’ ’ || instr[len] == ‘\r’ || instr[len] == ‘\n’) instr[len–] = ‘\0’;
char * tok = strtok(instr, " \r\n");
int state = 0; targx = 0, targy = 0;
while (tok)
switch (state)
case 0:
if (strcmp(tok, “T2”) == 0) state = 1;
case 1: targx = atoi(tok); state = 2; break;
case 2:
targy = atoi(tok);
if(strcmp(tok, “OK”) == 0) state = 3;
else state = 1000;
default: break; // Skip any additional tokens
tok = strtok(0, " \r\n");
if (targx != 0 && targy != 0){
int x = targx;
int y = targy;
SERIAL.print("# “);
SERIAL.print(x);
SERIAL.print(” “);
SERIAL.println(y);
SERIAL.print(”# ");
SERIAL.println(instr);
//Move stricker based on y coordinate
if (centery > targy){
//move clockwise
movement = abs(targy - centery)*13;
digitalWrite(smDirectionPin, HIGH);
for (int i = 0; i < movement; i++){
digitalWrite(smStepPin, HIGH);
delayMicroseconds(70);
digitalWrite(smStepPin, LOW);
//set dir to 0
dir = 0;
else if (centery < targy){
//move counterclockwise
digitalWrite(smDirectionPin, LOW);
//set dir to 1
dir = 1;
// write stricker coord and move to center
if( dir == 0){
else if(dir == 1){
//move clockwise
To make it easy for people to help you please modify your post and use the code button </>
so your code
looks like this
and is easy to copy to a text editor. See How to use the Forum
Your code is too long for me to study quickly without copying to my text editor.
Have you written a short program to make your motors move, and does that work properly?
If you need more help please post a link to the datasheet for your stepper motors and tell us what stepper motor driver you are using.
...R
Stepper Motor Basics
Simple Stepper Code
I am able to move the motor individually, but I am having trouble moving the motor to the desired coordinates. Below is a picture of the connections between motor, camera, and Arduino, I am using an EasyDriver as my motor driver.
#include <avr/io.h>
#define LEDPIN 13
#define INLEN 256
int dir;
int centerx = -195;
int centery = 475;
int targx;
int targy;
int movement;
int x;
int y;
delay(8000);
delay(200);
SERIAL.setTimeout(1500); //* changed
SERIAL.println("setpar serout Hard");
SERIAL.println("setmapping2 YUYV 320 254 60.0 JeVois ObjectTracker");
SERIAL.println("streamon");
    if (j == 0){
      byte len = SERIAL.readBytesUntil('\n', instr, INLEN);
      instr[len--] = '\0';
      while (len >= 0 && instr[len] == ' ' || instr[len] == '\r' || instr[len] == '\n') instr[len--] = '\0';
      while (tok)
        switch (state)
          case 0:
            if (strcmp(tok, "T2") == 0) state = 1;
          case 2:
            targy = atoi(tok);
            //if(strcmp(tok, "OK") == 0) state = 3;
            //state = 1000;
    x = targx;
    y = targy;
    SERIAL.print("# ");
    SERIAL.print(x);
    SERIAL.print(" ");
    SERIAL.println(y);
    //Move stricker based on x coordinate
    if (x > centerx){
      //move clockwise
      if(x > 270){
        x = 270;
       movement = abs(x - centerx)*13;
       if(movement > 5500){
          movement = 5500;
       if( y > 150){
        //set dir to 0
        dir = 0;
    else if (x < centerx){
      if(x < -700){
        x = -700;
          movement = 5500;
       if (y > 150){
      //set dir to 1
      dir = 1;
  if(j == 1){
    if(dir == 0){
    else if(dir == 1){
    //move clockwise
Image from Reply #2 so we don't have to download it. See this Simple Image Posting Guide
...R
I've had a look at your code but I'm afraid I can't follow it. You have all the code in loop(). For anything other than a trivial program it is much better to break the code into functions - for example your code in loop() might be something like
   checkCameraData();
   calculateMotorPosition();
   moveMotor();
Have a look at Planning and Implementing a Program
Also be sure to use the AutoFormat tool to indent your code consistently - that's especially necessary when you have a lot of code in a single function.
...R
