Hello,
I'm using an Arduino board to generate three square waves having a specific phase relationship. The output has a significant amount of jitter when viewed on a scope. It appears that the HIGH duration and LOW duration do not remain fixed. I've tried the code on an Uno, Due, and Mega2560 board with the same results. The code is very short and I've included it below.
Code summary: The program generates three outputs: a square wave with a 6ms period (about 165Hz), a 30us pulse in the middle of the 165Hz HIGH period, and a 2nd 30us pulse in the middle of the 165Hz LOW period. The two 30us pulses can have as much as 5us of jitter. I'm using this to test a circuit card that takes in an analog signal (I'm substituting the 165Hz square wave for the analog signal at the moment) and samples it during the positive peak and the negative peak.
What could be causing the timing to be inconsistent?
Thanks,
Mike
//defines d0 - d2 as the digital outputs on pins D0 thru D2
const int d3 = 3; //d0 is the "analog" output to the Test Card's analog input.
const int d4 = 4; // sampling signal 1
const int d5 = 5; // sampling signal 2
int p; // delay const used in the timing of the analog signal
int q; // delay const used in the timing of the 30us sampling signalssignals
pinMode(d3, OUTPUT);
pinMode(d4, OUTPUT);
pinMode(d5, OUTPUT);
p = 1500; // length of 1/4 of square wave representing the analog signal in microseconds
q = 50; // length 0f sampling pulse in microseconds
digitalWrite(d3, LOW); // presets analog signal LOW
digitalWrite(d4, LOW); // presets sampling signal 1 LOW
digitalWrite(d5, LOW); // presets sampling signal 2 LOW
digitalWrite(d3, HIGH); // sends analog signal HIGH
delayMicroseconds(p); // pause 1500us
digitalWrite(d4, HIGH); // sends sampling signal 1 HIGH
delayMicroseconds(q); // pauses 30us
digitalWrite(d4, LOW); // sends sampling signal 1 LOW
delayMicroseconds(p); // pauses 1500us
digitalWrite(d3, LOW); // analog signal goes LOW. End of one half of the cycle
digitalWrite(d5, HIGH); // sends sampling signal 2 HIGH
digitalWrite(d5, LOW); // sends sampling signal 2 LOW
delayMicroseconds(p); // pauses 1500us, end of loop. End of one full cycle. Repeats.
