As the title suggests, is this possible now?
Attached pic: R7 is a 0 ohm resistor joining two nets
No, it's not possible.
Well, you could design a special "net connector" component that didn't LOOK like a resistor, and had a DRC-violating package that actually did the joining. I made a set like this, for example:
I don't use Eagle but I've never seen a CAD package that will allow this, you have to rename one or both of the nets. In this case maybe to PC7-RESET if for some reason you really need to keep both names to make something clear.
Or pull a flanker like westfw suggests.
Rob
the net connector part seems like a novel solution. okay, thanks for your replies.
