hello I have a question, I do not know how to switch between programs with a button, what one does is evade objects autonomously and the other controls it through bluetooth
autonomous robot
#include <Servo.h> //Servo motor library. This is standard library
#include <NewPing.h> //Ultrasonic sensor function library. You must install this library
//our L298N control pins
const int LeftMotorForward = 7;
const int LeftMotorBackward = 6;
const int RightMotorForward = 4;
const int RightMotorBackward = 5;
//sensor pins
#define trig_pin A1 //analog input 1
#define echo_pin A2 //analog input 2
#define maximum_distance 200
boolean goesForward = false;
int distance = 100;
NewPing sonar(trig_pin, echo_pin, maximum_distance); //sensor function
Servo servo_motor; //our servo name
void setup(){
pinMode(RightMotorForward, OUTPUT);
pinMode(LeftMotorForward, OUTPUT);
pinMode(LeftMotorBackward, OUTPUT);
pinMode(RightMotorBackward, OUTPUT);
servo_motor.attach(10); //our servo pin
servo_motor.write(115);
delay(2000);
distance = readPing();
delay(100);
delay(100);
delay(100);
delay(100);
void loop(){
int distanceRight = 0;
int distanceLeft = 0;
delay(50);
if (distance <= 20){
moveStop();
delay(300);
moveBackward();
delay(400);
moveStop();
delay(300);
distanceRight = lookRight();
delay(300);
distanceLeft = lookLeft();
delay(300);
if (distance >= distanceLeft){
turnRight();
moveStop();
else{
turnLeft();
moveStop();
else{
moveForward();
int lookRight(){
servo_motor.write(50);
int distance = readPing();
delay(100);
return distance;
int lookLeft(){
servo_motor.write(170);
delay(100);
return distance;
delay(100);
int readPing(){
delay(70);
int cm = sonar.ping_cm();
if (cm==0){
cm=250;
return cm;
void moveStop(){
digitalWrite(RightMotorForward, LOW);
digitalWrite(LeftMotorForward, LOW);
digitalWrite(RightMotorBackward, LOW);
digitalWrite(LeftMotorBackward, LOW);
void moveForward(){
if(!goesForward){
goesForward=true;
digitalWrite(LeftMotorForward, HIGH);
digitalWrite(RightMotorForward, HIGH);
void moveBackward(){
goesForward=false;
digitalWrite(LeftMotorBackward, HIGH);
digitalWrite(RightMotorBackward, HIGH);
void turnRight(){
void turnLeft(){
control by bluetooth
//pines de los sensores
#define trig_pin A1
#define echo_pin A2
int distance = 100;
NewPing sonar(trig_pin, echo_pin, maximum_distance); //funciones de los sensores
char getstr;
const int LeftMotorForward = 7; //Declarar los pines del del motor LN1
const int LeftMotorBackward = 6; //LN2
const int RightMotorForward = 4; //LN3
const int RightMotorBackward = 5; //LN4
void _mForward() //Adelante
Serial.println("go forward!");
void _mBack() //Atras
Serial.println("go back!");
void _mleft() //Izquierda
Serial.println("go left!");
void _mright() //Derecha
void _mStop() //Detener
Serial.println("Stop!");
Serial.begin(9600); //Declarar los pines de salida
delay(100);
delay(50);
if (distance <= 20){ //Si la distancia es menor o igual a 20 cm
_mStop(); //Detente
delay(300);
_mBack(); //Regresa
delay(400);
_mStop(); //Detente
delay(300);
else{
getstr=Serial.read();
if(getstr=='F')
_mForward();
else if(getstr=='B')
_mBack();
delay(200);
else if(getstr=='R')// according to my robot. otherwise L
_mleft();
delay(200);
else if(getstr=='L') // according to my robot. otherwise R
_mright();
delay(200);
else if(getstr=='X')
_mStop();
int readPing(){
delay(70);
if (cm==0){
cm=250;
return cm;
