hi guys im having problems with trying to get a joycon "joystick" to work with a esp32, i got a normal joystick working perfectly, but now im trying to get this to work, i brought some hall effect joycon joysticks, i tested them in a joycon and they work perfect, the axis mapping is off and for the life of me i cant get it working %100 can you look in my code see if you guys can see anything that sticks out?
#include <BleGamepad.h>
#include <WiFi.h>
#include <WebServer.h>
#include <FS.h>
#include <SPIFFS.h>
// --- Pins Configuration ---
constexpr int JOYSTICK_X_PIN = 34;
constexpr int JOYSTICK_Y_PIN = 35;
constexpr int BUTTON_PIN = 32;
// --- BLE Gamepad ---
BleGamepad bleGamepad("Custom BLE Gamepad", "Your Name", 100);
// --- Axis Range ---
constexpr int GAMEPAD_MIN = -127;
constexpr int GAMEPAD_MAX = 127;
// --- Deadzone ---
constexpr int JOYSTICK_DEADZONE = 10; // Threshold for ignoring small movements
// --- Wi-Fi Credentials ---
const char* WIFI_SSID = "---------";
const char* WIFI_PASSWORD = "---------------;
// --- Web Server ---
WebServer server(80);
// --- Axis Mapping Function ---
int mapJoystickValue(int value) {
int deadzoneAdjusted = abs(value) < JOYSTICK_DEADZONE ? 0 : value;
return map(deadzoneAdjusted, -4095, 4095, GAMEPAD_MIN, GAMEPAD_MAX);
// --- Initialization Sequence ---
void initializeBluetooth() {
// Emulates Joy-Con initialization handshake
Serial.println("Initializing BLE for Joy-Con emulation...");
delay(100); // Optional timing adjustments for proper handshake
// --- Setup ---
if (!SPIFFS.begin(true)) {
Serial.println("Failed to initialize SPIFFS.");
return;
bleGamepad.begin();
initializeBluetooth();
pinMode(BUTTON_PIN, INPUT_PULLUP);
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print(".");
Serial.println("\nWi-Fi connected!");
server.begin();
// --- Loop ---
// Read joystick values
int xRaw = analogRead(JOYSTICK_X_PIN);
int yRaw = analogRead(JOYSTICK_Y_PIN);
// Map joystick values
int xMapped = mapJoystickValue(xRaw);
int yMapped = mapJoystickValue(yRaw);
// Debugging output
Serial.print("X Mapped: ");
Serial.println(xMapped);
Serial.print("Y Mapped: ");
Serial.println(yMapped);
// Update gamepad axes
bleGamepad.setAxes(xMapped, yMapped);
// Handle button state
if (digitalRead(BUTTON_PIN) == LOW) {
bleGamepad.press(BUTTON_1);
bleGamepad.release(BUTTON_1);
bleGamepad.sendReport();
server.handleClient();
