Joystick ADC interrupt
Preformatted textI want to use ADC interrupt and timer to save power when using joystick ?
But my code not work really good. I think because the way I switch between A0 and A1 . Could I have advise how read input from A0 and A1 using ADC interrupt
int check_amux = 0 ;
volatile boolean check_mpu;
volatile boolean adcDone;
volatile int adcReading_vert;
volatile int adcReading_horz;
byte adcPin [2] = { 0 , 1 };
boolean adcStarted;
TCCR1A = 0;// set entire TCCR1A register to 0
TCCR1B = 0;// same for TCCR1B
TCNT1 = 0;//initialize counter value to 0
// set compare match register for 1hz increments
OCR1A = 15624;// = (16*10^6) / (1*1024) - 1 (must be <65536)
// turn on CTC mode
TCCR1B |= (1 << WGM12);
// Set CS12 and CS10 bits for 256 prescaler
TCCR1B |= (1 << CS12) | (1 << CS10);
// enable timer compare interrupt
TIMSK1 |= (1 << OCIE1A);
sei();//allow interrupts
ADCSRA = bit (ADEN); // turn ADC on
ADCSRA |= bit (ADPS0) | bit (ADPS1) | bit (ADPS2); // Prescaler of 128
ADMUX = bit (REFS0) | (adcPin[check_amux] & 0x07) ; // AVcc and select input port
ISR(TIMER1_COMPA_vect){
check_mpu = true ;
adcDone = true ;
ISR (ADC_vect){
adcDone = false;
if (check_amux == 0){
adcReading_vert = ADC;
check_amux = 1;
else if ( check_amux == 1){
adcReading_horz = ADC;
check_amux = 0;
} // end of ADC_vect
if (adcDone == true)
adcStarted = false;
// do something with the reading, for example, print it
Serial.println("vertical");
Serial.println (adcReading_vert);
Serial.println("horizontal");
Serial.println (adcReading_horz);
  // if we aren't taking a reading, start a new one
 if (!adcStarted)
    adcStarted = true;
    // start the conversion
    ADCSRA |= bit (ADSC) | bit (ADIE);
@ohmybae, please edit your post, select all code and click the </> button to apply so-called code tags and next save your post. It makes it easier to read, easier to copy and prevents the forum software from incorrect interpretation of the code.
thank u , i just fix it
Colon?
Your code does not compile. The colon after setup does not belong there; check_amux is unknown.
Lowlevel stuff is not my strong point.
sorry , i will fix it
sorry i will fix it. cause it a long code so i pick out the part i want so forgot to include the initialize for check_amux
Please give a better description.
One thing might be that Serial.print does not show anything because you're missing a Serial.begin() in setup().
Please do not edit your opening post when posting new / modified code; just put it in a new reply.
thank u
the input not reading correctly like what i expected. it only read the vertical value of joystick and not read the horizontal . The problem might due to the switching between pinA0 and A1 . However , i dont know a better way to switch pin when using ADC interrupt on 2 pin . Furthermore , i think I had reach the limit to replies for today . So could i message u later on
boolean adcStarted;
 Serial.begin( 115200);
// turn on CTC mode
check_mpu = true ;
adcDone = true ;
ISR (ADC_vect){
adcDone = false;
check_amux = 1;
check_amux = 0;
adcStarted = false;
 if (!adcStarted)
    adcStarted = true;
As far as I can see, you never switch analog channels using the ADMUX register.
And I think you're making your life very complicated by using interrupts.
