Joystick Button/Switch Issue
So I'm working on a small project with the UNO that requires me to use the analog joystick's button fonctionality. However I just can't seem to get it to work. The joystick only outputs 0's no matter what I do, only rarely but somewhat randomly spitting out a 1.
Here's the code:
void setup() { pinMode(10, INPUT); Serial.begin(9600); }
void loop() { Serial.print(digitalRead(10)); delay(100); }
The joystick is just attached to 5v, GND, and SW to pin 10.
Are they the only connections to the joystick ? Where did you get the joystick from ?
Have you any idea how the switch is wired in the joystick ? Does it go to 5V or GND when pressed, for instance ?
The joystick it just one of these [attached] it should be outputting a HIGH digital on the SW pin when pressed.
Try this instead
  pinMode(10, INPUT_PULLUP);
  Serial.println(digitalRead(10));
  delay(100);
Change the baud rate to suit yourself
