Joystick button to toggle switch.
I'm in the process of building a Lego Technic Robotic arm. So far, we have 4 servos, 3 motors, 1 limit switch being used. Thus far, I have no major issues with programming. Everything seems to be functioning beautifully. Where I run into an issue is turning the joystick push buttons into toggle switches. So far, I can hold the button down for "HIGH" and release for "LOW". but when I try to integrate my known methods of "Toggle Switching" into the program, 1 of two things happen. either, it activates for a few seconds and then deactivates, back and forth on its own, or it just simply will not function at all. I've even attempted to add a pullup resister in the path of the switch wire. No difference.
To not risk messing up my main program, I've diverted back to an older and simpler IDE file to try and figure it out.
My first thought, is that the "else" is preventing things to run because I didn't add enough information to it. If so, then what do I need to add to it? Otherwise, maybe you guys can help me figure out my mistake?
#include <Servo.h>
Servo Xservo;
Servo Yservo;
int XSpin=11;
int YSpin=10;
int ledPin=7;
int buttonPin=2;
int buttonNew;
int buttonOld=1;
int ledState=0;
int XPin=A0;
int YPin=A1;
int SWpin=2;
int XVal;
int YVal;
int WVx;
int WVy;
int dt=100;
int dtB=100;
pinMode(XSpin,OUTPUT);
pinMode(YSpin,OUTPUT);
pinMode(ledPin,OUTPUT);
pinMode(XPin,INPUT);
pinMode(YPin,INPUT);
pinMode(buttonPin,INPUT);
Xservo.attach(XSpin);
Yservo.attach(YSpin);
XVal=analogRead(XPin);
WVx=(180./1023.)*XVal;
YVal=analogRead(YPin);
WVy=(180./1023.)*YVal;
buttonNew=digitalRead(buttonPin);
Xservo.write(WVx);
Yservo.write(WVy);
delay(dt);
Serial.print("X Value = ");
Serial.print(XVal);
Serial.print(" Y Value = ");
Serial.print(YVal);
Serial.print(" Switch State = ");
Serial.println(buttonNew);
delay(dtB);
if(buttonOld==0 && buttonNew==1){
if (ledState==0){
digitalWrite(ledPin,HIGH);
ledState=1;
else{
digitalWrite(ledPin,LOW);
ledState=0;
Thanks for any help guys!
Hello,
You declared buttonOld to 1 then you check if it's 0 and you don't do anything else with this variable. So this condition:if(buttonOld==0 && buttonNew==1){ will always be false
from what you said, If I declare it a "0", then the opposite is the case, it will always be true, and never false. But if I don't declare it and I just set up a digitalRead, then buttonNew and buttonOld will always be the same. ??
There must be an alternative method of creating a toggle switch from a joystick button.
You have to do something with "buttonOld", actually it is useless because you never change its value.
Search about "state change detection"
Or just use a library such as this one: GitHub - JChristensen/JC_Button: Arduino library to debounce button switches, detect presses, releases, and long presses
