joystick code error?
I am building a usb handbrake for sim racing copying this video DIY Analog USB Handbrake - YouTube
Now I have copied the code in the video but it will not compile.
I am using a pro micro but windows 10 sees it as a leonardo
Now here is the code
#include <Joystick.h>
{pinMode(A3, INPUT);
   Joystick.begin();}
const int pinToButtonMap = A3;
{int pot = analogRead(A3);
int mapped = map(pot,525,870,0,255);
{Joystick.setThrottle(mapped);}}
And here is the error message
R:\Mark\new gaming sim pc\handbrake mod\Analog-E-Brake-master (1)\Analog-E-Brake-master\ANALOG_EBRAKE\ANALOG_EBRAKE.ino: In function 'void setup()':
ANALOG_EBRAKE:7:12: error: expected unqualified-id before '.' token
Joystick.begin();}
R:\Mark\new gaming sim pc\handbrake mod\Analog-E-Brake-master (1)\Analog-E-Brake-master\ANALOG_EBRAKE\ANALOG_EBRAKE.ino: In function 'void loop()':
ANALOG_EBRAKE:15:10: error: expected unqualified-id before '.' token
exit status 1
Now if anyone can help me out that would be great.
Aren't you forgetting to create a joystick object? Look at the examples to see how to use the library.
Object declaration:
Joystick_ Joystick;
Here is your code with the joystick object declared and code formatted with the IDE tool, autoformat (ctrl-t or Tools, Auto Format). It compiles with no errors or warnings. It is, however, untested as I do not have a Leo.
Joystick_ Joystick;  // ********  added declaration
   pinMode(A3, INPUT);  // ************ unnecessary as the pin defaults to input
   Joystick.begin();
const int pinToButtonMap = A3;  // *********** not used, why bother
   int mapped = map(pot, 525, 870, 0, 255);
groundFungus:
Object declaration:
Joystick_ Joystick;
Joystick.begin();
Thanks for that I have tried but when I compile it I get the following error
Arduino: 1.8.14 Hourly Build 2021/01/29 11:33 (Windows 10), Board: "Arduino Leonardo"
ANALOG_EBRAKE:3:1: error: 'Joystick_' does not name a type; did you mean 'Joystick'?
Joystick
ANALOG_EBRAKE:10:12: error: expected unqualified-id before '.' token
Joystick.begin();
ANALOG_EBRAKE:20:15: error: expected unqualified-id before '.' token
exit status 1
option enabled in File -> Preferences.
So there must be more than one version of the Joystick library and I picked the wrong one. Please provide a link to the library that you are using.
Go to the examples that come with the library that you have and look at how the Joystick object is declared.
Did you try:
Joystick joystick;  // ********  note lower case j
   pinMode(A3, INPUT);
   joystick.begin();  // ********  note lower case j
      joystick.setThrottle(mapped); // ********  note lower case j
The library I am using can be downloaded here GitHub - MHeironimus/ArduinoJoystickLibrary: An Arduino library that adds one or more joysticks to the list of HID devices an Arduino Leonardo or Arduino Micro can support.
I have fixed it I just used a different pc and all compiled and uploaded fine. so thanks for your help
