hi all,
i'm making a "handbrake" for my PC to play games with my G920 wheel, but i'm having some conflicts. when i connect both the wheel + the handbrake I can calibrate the wheel but i can't calibrate the hand brake. in games when i connect the handbrake i get some throttle conflicts, basicly the game recognize the aceleration but the car doesn't move, this only happens with the handbrake connected. you think there is any code that can help resolve this or even another joystick library? Here is the code + the joystick library.
it consists in a pedal + six buttons.
#include <Joystick.h>
pinMode(A0, INPUT);
// Initialize Button Pins
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
pinMode(4, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
pinMode(6, INPUT_PULLUP);
pinMode(7, INPUT_PULLUP);
// Initialize Joystick Library
Joystick.begin();
// Constant that maps the phyical pin to the joystick button.
const int pinToButtonMap = 2;
// Last state of the button
int lastButtonState[6] = {0,0,0,0,0,0};
// Read pin values
for (int index = 0; index < 6; index++)
int currentButtonState = !digitalRead(index + pinToButtonMap);
if (currentButtonState != lastButtonState[index])
Joystick.setButton(index, currentButtonState);
lastButtonState[index] = currentButtonState;
delay(50);
{int pot = analogRead(A0);
int mapped = map(pot,0,1023,0,255);
{Joystick.setRudder(mapped);}}
Joystick.h
Copyright (c) 2015, Matthew Heironimus
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#ifndef JOYSTICK_h
#define JOYSTICK_h
#include "HID.h"
#if ARDUINO < 10606
#error The Joystick library requires Arduino IDE 1.6.6 or greater. Please update your IDE.
#endif
#if !defined(USBCON)
#error The Joystick library can only be used with a USB MCU (e.g. Arduino Leonardo, Arduino Micro, etc.).
#endif
#if !defined(_USING_HID)
#warning "Using legacy HID core (non pluggable)"
#else
// Joystick (Gamepad)
class Joystick_
private:
bool autoSendState;
int8_t xAxis;
int8_t yAxis;
int8_t zAxis;
int16_t xAxisRotation;
int16_t yAxisRotation;
int16_t zAxisRotation;
uint32_t buttons;
uint8_t throttle;
uint8_t rudder;
int16_t hatSwitch[2];
public:
Joystick_();
void begin(bool initAutoSendState = true);
void end();
void setXAxis(int8_t value);
void setYAxis(int8_t value);
void setZAxis(int8_t value);
void setXAxisRotation(int16_t value);
void setYAxisRotation(int16_t value);
void setZAxisRotation(int16_t value);
void setButton(uint8_t button, uint8_t value);
void pressButton(uint8_t button);
void releaseButton(uint8_t button);
void setThrottle(uint8_t value);
void setRudder(uint8_t value);
void setHatSwitch(int8_t hatSwitch, int16_t value);
void sendState();
extern Joystick_ Joystick;
#endif
#endif
