Joystick pins
Can anyone tell me how to connect joystick with Node MCU ???????
Maybe, if you tell use what hardware you're using (post links to both, the Node MCU, which is only a class of devices, and the joystick!).
I just want to know that node MCU having only one analog pins so how can we connect the joystick pin means x and y pins in node mcu.
It looks like you mean an analog joystick, an information we didn't have before. The same applies for "Node MCU", which is a form factor but not an actual hardware.
As for above problem: How about using an external ADC?
