Joystick robot controller
Hi all, first of all introduce myself, my name is Eloi and I'm building a robot. These are the characteristics of the robot and its controller:
Controller:
  • 1 Arduino Mega 2560 R3
  • 1 Joystick
  • 5 push buttons
  • One lcd 40x4
  • 1 matrix numbers
  • One antenna rf
robot:
  • 1 MD22 controller motors (0-255 analog pins)
  • 4 Motors (two are coupled)
  • One lcd 16x2
  • One gps
  • 1 bluetooth
  • 1 Rf Antenna
The problem is this: The system sends and receives data from the joystick perfectly, but not how to do that with a single joystick to control the two motors perfectly.
The robot is as follows:
m1--- ---m2
m1--- ---m2
I need help with the code please, for the moment the robot code I have is this:
#include <LiquidCrystal.h>
#include <Wire.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
#define md22Address 0x58                              // address of md 22 (all mode switches on)
#define softReg 0x07                                  // Byte for reading software register
#define motor1 0x01                                   // Byte for first motor
#define motor2 0x02                                   // Byte for second motor
#define accelReg 0x03
  Serial.begin(19200);
  Serial3.begin(19200);
  //Pantalla
   lcd.begin(16, 2);
a13 = Serial3.parseInt();
    // do it again:
   a14= Serial3.parseInt();
if(((a13 >= 490 && a13 <= 560) && (a14 >= 490 && a14 <= 560)))
      Wire.beginTransmission(md22Address);                // Set first motor to a speed of 255
      Wire.write(motor1);
      Wire.write(128);
      Wire.endTransmission();
      Wire.beginTransmission(md22Address);                // Set second motor to stop
      Wire.write(motor2);
      Wire.write(128);
      int x1 = map(a13, 1023, 0, 0, 255);
      int x2 = map(a14, 1023, 0, 0, 255);
           Wire.beginTransmission(md22Address);                // Set first motor to speed 0
            Wire.write(motor1);
            Wire.write(x1);
            Wire.write(motor2);
            Wire.write(x1);
          lcd.setCursor(0,1);
          lcd.print(x1);
          lcd.print(",      ");
Before you're moved, see this thread. look at reply #19.
http://forum.arduino.cc/index.php?topic=262762.msg1855000#msg1855000
El problema es
that this is the English language section of the forum, and your post isn't in English.
Thank you HazarsMins!
And Pauls, I spanish but the post is in english!
Well, it wasn't before. Thanks for making me look like an idiot.
Below is some two pot (like a joystick) test code for controlling servos. Might be somewhat similar to what you are looking for.
//zoomkat dual pot/servo test 12-29-12
//view output using the serial monitor
#include <Servo.h>
Servo myservoS1;
Servo myservoS2;
int potpinS1 = 0;  //analog input pin A0
int potpinS2 = 1;
int newvalS1, oldvalS1;
int newvalS2, oldvalS2;
  myservoS1.attach(2);
  myservoS2.attach(3);
  Serial.println("testing dual pot servo");
  newvalS1 = analogRead(potpinS1);
  newvalS1 = map(newvalS1, 0, 1023, 0, 179);
  if (newvalS1 < (oldvalS1-2) || newvalS1 > (oldvalS1+2)){
    myservoS1.write(newvalS1);
    Serial.print("1- ");
    Serial.println(newvalS1);
    oldvalS1=newvalS1;
  newvalS2 = analogRead(potpinS2);
  newvalS2 = map(newvalS2, 0, 1023, 0, 179);
  if (newvalS2 < (oldvalS2-2) || newvalS2 > (oldvalS2+2)){
    myservoS2.write(newvalS2);
    Serial.print("2- ");
    Serial.println(newvalS2);
    oldvalS2=newvalS2;
  delay(50); //slow down looping to better read serial monitor
