Thanks for replying. It's the thumb-stick click on a standard ALPS thumb-stick (e.g. Xbox One / PS4 type)... a simple digital momentary push-button switch... but that's not really the issue. It's the actual analogue joystick not behaving in an analogue fashion as regards moving the mouse-pointer.
All I get is a fixed speed in 8-directions - no matter how gently or strongly I push the stick. I've tried tweaking the code a little with this:
#include <Mouse.h>
/* HID Joystick Mouse Example
by: Jim Lindblom
date: 1/12/2012
license: MIT License - Feel free to use this code for any purpose.
No restrictions. Just keep this license if you go on to use this
code in your future endeavors! Reuse and share.
This is very simplistic code that allows you to turn the
SparkFun Thumb Joystick (Thumb Joystick - COM-09032 - SparkFun Electronics)
into an HID Mouse. The select button on the joystick is set up
as the mouse left click.
#include <Mouse.h>
int horzPin = A0; // Analog output of horizontal joystick pin
int vertPin = A1; // Analog output of vertical joystick pin
int selPin = 7; // select button pin of joystick
int vertZero, horzZero; // Stores the initial value of each axis, usually around 512
int vertValue, horzValue; // Stores current analog output of each axis
const int sensitivity = 200; // Higher sensitivity value = slower mouse, should be <= about 500
int mouseClickFlag = 0;
//int invertMouse = 1; //Invert joystick based on orientation
int invertMouse = -1; //Noninverted joystick based on orientation
pinMode(horzPin, INPUT); // Set both analog pins as inputs
pinMode(vertPin, INPUT);
pinMode(selPin, INPUT); // set button select pin as input
digitalWrite(selPin, HIGH); // Pull button select pin high
delay(1000); // short delay to let outputs settle
vertZero = analogRead(vertPin); // get the initial values
horzZero = analogRead(horzPin); // Joystick should be in neutral position when reading these
Mouse.begin(); //Init mouse emulation
vertValue = analogRead(vertPin) - vertZero; // read vertical offset
horzValue = analogRead(horzPin) - horzZero; // read horizontal offset
if (vertValue != 0)
Mouse.move(0, (invertMouse * (vertValue / sensitivity)), 0); // move mouse on y axis
if (horzValue != 0)
Mouse.move((invertMouse * (horzValue / sensitivity)*-1), 0, 0); // move mouse on x axis
if ((digitalRead(selPin) == 0) && (!mouseClickFlag)) // if the joystick button is pressed
mouseClickFlag = 1;
Mouse.press(MOUSE_LEFT); // click the left button down
else if ((digitalRead(selPin)) && (mouseClickFlag)) // if the joystick button is not pressed
mouseClickFlag = 0;
Mouse.release(MOUSE_LEFT); // release the left button
But no luck.
